Old 09-04-2010, 05:07 PM   #1
syntax
syntax's Avatar
yaris checklist before going to al khobar
mga kayaris
pwede mag suggest kayo ng ipapacheck or iccheck sa sasakyan bago mag byahe sa al khobar? both jonimac and I are over 15K na sa yaris, but nagpasked kami ng check up / maintenance sa ALJ after eid holidays pa dahil daw sa dami ng naka sked, it would help alot kung may suggestions kayo, we're planning to
1. change the oil, and oil filter
2. replace air filter
3. top up brake fluids
4. spare tire and tools check
5. coolant level
nu pa kaya mga kayaris?
Old 09-04-2010, 05:13 PM   #2
jonimac
jonimac's Avatar
Send a message via Yahoo to jonimac
Originally Posted by syntax View Post
mga kayaris
5. coolant level
Do I need to rotate the tires at this moment? or after the trip na? (Pass ka d2 bro)
jonimac is offline   Reply With Quote
Old 09-04-2010, 09:16 PM   #3
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
@syntax, I am planning to go to ALJ before the meet, so you mean 50/50 lang ang chances ko to have the service from them? Marami pa naman kailangan gawin kay mica like change oil, coolnt check, etc.
rye7jen is offline   Reply With Quote
Old 09-05-2010, 01:58 AM   #4
syntax
syntax's Avatar
@ rye sabi samin ng maintenance or service advisor lahat daw ay kailangan may appointment, at may nakasabay kami na corolla na magpapacheck up ng 5K lang ay ganun din ang sinabi, ilan na ba kilometer reading ni mica?
@ jonimac most probable ay kailangan na natin i rotate ang tires ni minie at para mag adjust ulit ang suspensions sa pagrotate ng tires, tawag ka lang pre if you need help.
Old 09-05-2010, 06:16 AM   #5
jonimac
jonimac's Avatar
@ jonimac most probable ay kailangan na natin i rotate ang tires ni minie at para mag adjust ulit ang suspensions sa pagrotate ng tires, tawag ka lang pre if you need help.[/QUOTE]
Thanks Bro, siguro sabay na natin patira kapag nagpa-change oil tayo dun sa mekaniko ni duke kamo, less pagod ba Kelan ba ito?
Old 09-05-2010, 06:18 AM   #6
zsazsa zaturnnah
zsazsa zaturnnah's Avatar
Drives: 2010 Yaris YX
Yun ba ang effect ng rotation maliban sa magpantay ang pagkapudpod? I meant, may effect sya sa suspension?
zsazsa zaturnnah is offline   Reply With Quote
Old 09-05-2010, 06:29 AM   #7
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
tol hindi ako sa mekaniko ako nagpapa change oil sa gas station lang pero 4 years na ako dun suki
duke_afterdeath is offline   Reply With Quote
Old 09-05-2010, 06:44 AM   #8
syntax
syntax's Avatar
sa pagkakaalam ko zsazsa, kasi kapag nag rotate ka ng tires, mag iiba ulit ung parang feel ng suspension sa tire dahil hindi ito ang original nyan tire na na settle ang mga shocks at springs., well ito lang ang sa palagay ko lang
Old 09-05-2010, 06:45 AM   #9
syntax
syntax's Avatar
dun naman sa suki kong petromin ako nagpa change oil dati, suki na rin dahil may libre ako oil filter lagi wehehehe,
magkano kaya ang OEM air filter?
Old 09-05-2010, 10:22 AM   #10
trebparadise
Drives: sedan yaris y
Ang presyo OEM air filter ay 60sr
trebparadise is offline   Reply With Quote
Old 09-05-2010, 10:52 AM   #11
jonimac
jonimac's Avatar
Yonnn! Thanks treb.
eto na ba yung orig?
Old 09-05-2010, 11:03 AM   #12
syntax
syntax's Avatar
salamat treb
Old 09-05-2010, 11:37 AM   #13
trebparadise
Yonnn! Thanks treb.
original yung pinalit ko. 17801-21050 DENSO made in japan
Old 09-06-2010, 04:52 AM   #14
zsazsa zaturnnah
Nag pa 5K service ako the other day ... the quote before Kermit gets in the workshop @ (Toyota) @ 9AM was SR. 120.00 ... when I collected Kermit @ 1pm ... naging SR. 96 na lang ... may isang invoice worth SR. 50 for labor charges na free ... guess ito yong adjustment sa break ... kasi nireklamo ko na pag nag full break ako may grinding sound sa harap ko (driver's side) ...
Old 09-06-2010, 04:56 AM   #15
syntax
syntax's Avatar
ate zsazsa, nagpunta ka lang sa toyota? hindi ka nagpa sked ng appointment?
Old 09-06-2010, 05:00 AM   #16
zsazsa zaturnnah
Naman ... parang kotche ... as in Toyota Corolla GL ... Ganda Lang!
In fairness, diva nabanggit ko na nasa kasukalan at pwet sila ng Rakah ... kaya kakaunti ang nagpupunta duon at Ramadan pa ... kaya lang nalusaw ako sa araw ... kasi naiwan si Kermit @ 9am then come back pa ako ng 1pm ... kaya super walk with faith in your heart ang lola mo under the sun ... bwisit ... ang tindi ng humid that day ... kaya tamang Aleck Bovick ang lola mo ... TAMPISAW sa PAWIS ...
Old 09-06-2010, 05:21 AM   #17
syntax
syntax's Avatar
ganun ba? indi kasi kami gaanong ka kagwapuhan ni jonimac kaya hindi naman nakaya ng GL nung nagpunta kami sa ALJ naseem, na turn down pa rin kami at kailangan magpa appointment muna then saka issked ang 15K check up ni minie at shadow.
Old 09-06-2010, 06:36 AM   #18
zsazsa zaturnnah
Ay ganun?
