Old 09-16-2010, 11:25 PM   #1
Hershey
IDEMITSU engine oil : new 1 to me ...
looks to be of good quality . http://www.idemitsu-ils.com.sg/index...ist&CateID=113 . They also claim to be used as factory fill oil for many car manufacturers . Wonder if TOYOTA is one of them ?
Old 09-16-2010, 11:44 PM   #2
sleey0
Drives: 2008 Yaris LB
No, that is Honda's factory fill. It is VERY good oil.
Ours is Nippon. Be aware that Nippon makes ENEOS, which I use, but doesn't have as good of an add-pack as the Toyo 0W20 (but I won't use 0W20).
And I would be willing to bet my Yaris that the oil Idemetsu sells to the public is different than the Honda-spec oil. just like Nippon/Toyo.
FWIW, I would go to a Honda dealer and pick up there oil before I would buy that. If Toyo had full synth 5W30 or 0W30 I would use it. The Toyo branded 0W20 is every bit as good as the Honda spec Idemetsu.
sleey0 is offline   Reply With Quote
Old 09-16-2010, 11:59 PM   #3
Hershey
they have a synthetic 75w-90 gear oil as well , www.ilacorp.com/images/web_75w90.pdf . Not sure if it's GL-4 or 5 .
Old 09-17-2010, 12:10 AM   #4
Hershey
Could these be a true synthetic ? The Technical Data Sheet for the their 5w-30 seems impressive , http://www.idemitsu-ils.com.sg/Uploa...W30%20Fsyn.pdf .
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 01:55 PM
Spilled oil on engine eii DIY / Maintenance / Service 11 01-28-2009 11:30 AM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
