Old 09-27-2010, 09:44 AM   #1
Frankd1
Drives: 2008 RS, 5spd
Is there a ride height difference between these two OEM tires?
I was just wondering if there is an overall ground clearance difference between these two OEM tires: 185/60-15 and 175/65-14?
I currently have the 15" on my Yaris RS hatch back but I'm looking at the 14" for my winter tires mounted on steelies (General Arctic Altimax), I know the 14's would probably perform better in the snow because they are more narrow so I'm thinking along that route.....
Frankd1 is offline   Reply With Quote
Old 09-27-2010, 10:13 AM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
185/60/15 = 23.7" diameter
175/65/14 = 23.0" diameter
This information is readily available if you look at the Official YARIS Wheel & Tire Guide:
http://www.yarisworld.com/forums/showthread.php?t=5021
EDIT:
So, 175/65/14 would certainly work for the winter, but you could also run:
175/70/14 = 23.7" diameter
185/70/14 = 24.3" diameter
Old 09-27-2010, 04:18 PM   #3
Frankd1
Thanks for the info and the link! I will likely go with the 175/65/14 as it is an OEM size and will likely give better traction in the snow vs. the 15"......and the ride height/ground clearance is negligible, I highly doubt 0.7" extra clearance with the 15's is gonna make a big difference in the snow!
Thanks again!
Old 09-27-2010, 04:50 PM   #4
MUSKOKA800
MUSKOKA800's Avatar
185/60-15 summer and 175/65-14 winter is my set-up. It drops my sedan nearly 1/2" when the winter boots are mounted.
I'm planning to change to 175/70/14 Ice-X for this coming winter. They will stand the same 23.7" diameter as the summer tires and should make it easier to negotiate deep snow and plow berms which has been challenging in my already lowered condition.
Old 09-27-2010, 05:51 PM   #5
Frankd1
I can see it being an issue with your car if its already lowered but I'm thinking 1/2" or less overall ride height shouldn't make too much of a difference for me with my stock
RS HB going from 185/60/15 to 175/65/14....
Plus Tirerack.com has the General Arctic Altimax in the 175/65/14 size but I don't think they have it in 175/70/14......
Bridgestone Ecopia EP100 Tires jackrabbitnomore Fuel Economy Forum 12 03-27-2010 12:30 AM
My review of hankook tires 205/55/15 on stock rims YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 09-30-2009 01:01 AM
can someone measure stock ride height? thebarber Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 07-29-2009 02:02 PM
Stiffer suspension - same ride height? fuji Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 01-13-2009 07:53 PM
stock ride height or spring sag? mikeukrainetz General Yaris / Vitz Discussion 5 12-21-2006 01:00 PM
