Old 10-05-2010, 04:30 PM   #1
Patitwelve
Drives: Toyota Yaris 1,8 TS Compressor
Send a message via ICQ to Patitwelve
break line: 1,5 RS vs. 1,8 TS
Hey!
I drive a 2008 Toyota Yaris TS with 1.8 liter engine (2ZR-FE). The engine have stock 133 HP.
Next month i’ll install a supercharger, 2,5 inch exhaust and air incooler from Bemani (Switzerland).
The performance after this conversion will be at 215 HP.
I would like to modificate the breaks too, because of this high performance. So there are 2 options:
1) A complete beak system from D2 Racing (6 break pistons, stainless steel break lines, drilled + slotted rotor -> about 800 Euro
2) Swap the break pad with better pads, and install stainless steel break lines
For version nr. 2 i could buy some break lines in the USA:
http://shop.microimageonline.com/Sta...-AP-ssbl-1.htm
Does everyone know if these lines apply to my car? Are the different break systems in Germany (a German 1.8 TS is built in Japan) and the American Yaris?
Thank you so much!
Patrick
Patitwelve is offline   Reply With Quote
Old 10-14-2010, 08:39 AM   #2
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
personally. id just upgrade to some good grip tires and throw on some hawk or other performance brake pads and the stainless steel lines also. i think the 6 piston calipers and slotted/drilled rotors are overkill and more for looks than performance..
Old 10-14-2010, 04:34 PM   #3
Patitwelve
okay thank you!!! i'll do it on the same way, after installing the supercharger.
DIY A/C low pressure line insulation syntax Middle East 291 06-17-2021 02:05 AM
My Hand Break goes on and off ??? derickveliz2 General Yaris / Vitz Discussion 3 01-20-2010 01:18 PM
Will XA XB's brake line fit our Yaris?? AlainMikli Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-04-2009 01:22 AM
Installing a external in line transmission filter. YarisSedan Performance Modifications 1 03-31-2009 08:03 PM
