Old 10-06-2010, 07:22 PM   #1
c-dub
Drives: 2008 yaris
need info on a 08 with tranny leak
i'm a total newb to the import scene, my whole life has been spent under ford mustangs and bronco's' the other day i put the wifes yaris on a lift for a oil change and found a class 1 oil leak on the bottom of what i guess is the tranny. i should have got a pic, but thought it would be going to the dealer for warranty work. turns out warrenty was up at 65,000 miles, wife thought it was one hundred. anyway she was told that the tranny never needed service and never add fluid. how can i check and fill if needed? were can i get a shop repair manual as i feel i'll be under this car more in the future.
c-dub is offline   Reply With Quote
Old 10-06-2010, 09:22 PM   #2
Here's the link to the 07 service manual, which is posted here. Everything is the same for her 08. The documentation for both the AT and the MT are there.
http://www.etimago.com/yaris/repairmanual/
Old 10-06-2010, 10:03 PM   #3
c-dub
Drives: 2008 yaris
thats what i needed. now i can find the issue. thank you for the link, just cant tell the wife or my hony do list will get real long real fast.
Old 10-06-2010, 10:56 PM   #4
Hershey
Are you sure it's the tranny gear oil ? Might want to take a look for motor oil at the back of the engine on the passenger side nearest to the timing chain cover . It can run all the way from the top of the block to the oil pan and down under . Tell us what you discover . Post pics if possible and good luck on finding the source .
Old 10-07-2010, 08:01 AM   #5
c-dub
Drives: 2008 yaris
not sure of anything right now. its not a major leak and i thought it was still under warranty @ 65k. guess not. next oil change i'll know a little more. it looks/ tasted like gear oil, thought all new gear boxes used a auto fluid in them, but i'm still way behind the curve on these rides. right now it looks like the seam where the manual trans sub cover meets the trans axle (the lowest point of course). fluid looked to clean to be motor oil. we will see.
Whistle at idle - vacuum leak, induction side RichieRoo General Yaris / Vitz Discussion 17 12-16-2022 05:53 AM
Auto tranny drain plug Yawesh General Yaris / Vitz Discussion 4 09-16-2010 11:54 PM
Is my auto tranny dying? eii DIY / Maintenance / Service 4 03-12-2010 03:03 PM
$1,600 Government Rebate on Fatt Batt Insulation or Solar Hot Water Systems Info. *MAD DOG* Australia 1 03-27-2009 09:44 AM
tranny has really loosened up - feels great! tekmoe General Yaris / Vitz Discussion 7 03-12-2007 06:14 PM
