Old 10-07-2010, 03:04 PM   #1
edzzzzzzzzzz
NOOB :)
Drives: 2009 5-door hatch daily driver
adding camber
hey guys, am new to this forum and have not read most past threads, but can someone help me with DIY tips on adding camber onto front wheels? i have done so to my rears but front shocks boggles my mind. here are some pic of my rears cambered with stock rims. Thx in advance :)
edzzzzzzzzzz is offline   Reply With Quote
Old 10-07-2010, 03:20 PM   #2
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Wow that's a lot of camber!
Old 10-07-2010, 03:55 PM   #3
BailOut
Steals terrorist's lunch
BailOut's Avatar
Adding camber to a daily driver will cause lots of uneven wear, which is just silly, but even if your car is a pure track setup that is simply too much camber in the rear. Professional racers rarely run with more than 3-4 degrees of negative camber for road courses but yours is at least 6 degrees.
- Brian
Share the Road
Old 10-07-2010, 04:53 PM   #4
33OH
Drives: '08 Yaris
Camber bolts for the front, sold at MicroImageOnline.com.
Old 10-07-2010, 05:07 PM   #5
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
Only use them if you are running wider wheels and wide rubber(205,215,etc). It's for the guys that rub alot of when they are lowered. You are using factory wheels, so ther is no need for them.
marlondog is offline   Reply With Quote
Old 10-07-2010, 05:24 PM   #6
^ He has no 'need' for camber in the back either. I suspect he is just going for the 'look'.
Old 10-07-2010, 10:36 PM   #7
marlondog
marlondog's Avatar
^There's no 'need' for most of these mods people do on their cars. It will just 'look' silly if he has tucked in wheels with wild negative camber. Maybe he can get some beefier tires and some wheel spacers to fill in the wells, and it might work. Since he has so much room to work with in those fender wells, he could be the 1st person on this site to do the "positive camber" thing. Instead of the wheels sticking out, they will be poking in.
Old 10-08-2010, 01:15 PM   #8
edzzzzzzzzzz
NOOB :)
thx 330H I will def. look into it..
thx for the input marlondog, i am trying to create a low but "quality look" stance as those beemers on stancework. my dream wheel BBS RS or LMS in 15 or 16 inch sizes are not available on the used wheel market yet, if they do I will snatch them up right away hahaha... as if right now am just preparing for em.
next project is to get some cambers for my fronts :)
Old 10-08-2010, 01:23 PM   #9
derickveliz2
Where is Jakarta?
Old 10-08-2010, 01:39 PM   #10
kimona
kimona's Avatar
Drives: 2014 White VITZ
There is no need for camber adjustments to your daily driver. BTW, your car looks absolutely ridiculous with the adjustments you've already made to the rear, and you are asking for problems and added expense down the road.
Old 10-08-2010, 02:18 PM   #11
detroiter
detroiter's Avatar
Jakarta...capital of Indonesia
Old 10-08-2010, 04:52 PM   #12
severous01
have fun with tires.
you're gonna shred them.
you gotta slot the holes in the upper strut mount, or get a camber/caster kit
Old 10-08-2010, 05:10 PM   #13
first things first - why not?
next: a little negative camber in front (way less than you show for the rear in your picture) is GOOD for handling and DOES NOT affect tire wear (up to -1.5 is true for this statement), no matter what tires and wheels you are running.
So much misinformation gets posted on here. :: sigh ::
anyways, front adjustable camber bolts for the Yaris:
http://shop.microimageonline.com/Adj...olts-81270.htm
Old 10-08-2010, 11:27 PM   #14
Lower more and get some wide, low offset rims. Then it'll fit more.
Old 10-09-2010, 01:44 AM   #15
derickveliz2
I have 1.5 degrees in the rear, thanks to Micro Image! and I really like it!
Old 10-09-2010, 11:44 AM   #16
detroiter
detroiter's Avatar
how do you put on those rear camber additions?
Old 10-09-2010, 01:33 PM   #17
the SPC shim kit comes with instructions, you basically snap off certain tabs to get the camber and toe you want, then mount it behind the wheel. It's a one-use plastic shim.
Old 10-09-2010, 02:32 PM   #18
detroiter
detroiter's Avatar
Do you have to disassemble the rear shocks and springs or is it something you can just jack up the rear of the car, put them in and lower it down?
Adjustable Camber Bolts cali yaris Micro Image 30 12-11-2009 09:38 AM
New Product: Penguin Garage Rear Camber Shims! Penguin Garage Penguin Garage 11 10-22-2009 10:20 PM
DIY adding extra power outlets and usb power outlets on the dash to use phone as GPS julienrl DIY / Maintenance / Service 1 08-31-2009 10:06 AM
Are camber bolts needed after installing springs? CtrlAltDefeat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 02-01-2009 12:19 AM
Camber Plates (Gauging Interest) misformartin Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 01-07-2009 11:21 PM
