Old 10-14-2010, 03:11 AM   #1
syntax
syntax's Avatar
tires squealing when turning
guys, i noticed when i'm turning at aroung 55ish km/hr my front tires are squeling, i have an aftermarket rims and 195x55xR15 tires,32psi front 30psi rear and on stock suspension, do i need to get an alignment? but when driving straight at around 100km/hr it is not wiggling or something.,is it my tires that's losing it's grip? any ideas
thanks
Old 10-14-2010, 06:43 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
you're losing traction.
jesus, has it come to this?
Old 10-14-2010, 08:58 AM   #3
MUSKOKA800
MUSKOKA800's Avatar
Understeer / plowing / pushing... all common issues with front-wheel drive cars including the Yaris in OEM suspension trim. It could also be a tire pressure issue or poor quality rubber. Try adjusting your front tire pressure.
Adding a rear anti-sway bar will help reduce understeer with zero negative effect on ride quality. Every Yaris should have one. If for nothing else but safetys sake. The car is much more stable after one is bolted on. And they're inexpensive.
Old 10-14-2010, 02:36 PM   #4
ddongbap
I was wondering that too, but I thought there was something I was missing.
Old 10-24-2010, 11:44 AM   #5
squirt1982
Drives: 2007 Liftback
Poor quality rubber in my experience. Sorry. Open differential, alignment good, not a whole lot else it could be.
squirt1982 is offline   Reply With Quote
Old 10-24-2010, 04:42 PM   #6
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
Ease way off the accelerator while cornering. Pinning it in a FWD car won't make you corner any faster. Matter of fact it's more of the opposite.
Old 10-24-2010, 05:19 PM   #7
djct_watt
Drives: 2010 NCP91 5spd
If you're driving hard, try raising your tire pressure for a free mod. I would push it to 38-42 all around. But yeah, a sway bar (or full suspension setup) will help to take some of the load off of that outside tire. And last but most importantly, the quality of the rubber will make a HUGE impact. But IMO, even with 55 series tire, the stock Yaris suspension has a huge propensity to really push the outside tire to roll onto it's edge, likely because of the massive body roll and high center of gravity. Pumping up the tires to max inflation does wonders, and above all else, a sway bar will give you more than enough useable traction for street use.
djct_watt is offline   Reply With Quote
Old 10-24-2010, 06:26 PM   #8
SilverBack
Joey
SilverBack's Avatar
^Raising tire pressure in the front would reduce grip and cause more understeer. It's happened to me in past Auto-X events when I forgot to let out a little bit of air before my first run.
Whatever the OP decides on, the front should have a lower PSI than the rear, unless he likes feeling like he's driving on butter lol
And I agree with the swaybar comments 100%. Should've been an OEM part
Old 10-24-2010, 06:33 PM   #9
djct_watt
Yes, I agree for most cases. But 32/30 F/R on 195/55r15 (essentially the same sidewalk height as stock) is very low, IMO, for aggressive driving. When ever I did a shoe polish test on the sidewalls below 38, I'd get significant roll over on the fronts. But yes, rear pressure should be higher than front for most cases.
Old 10-24-2010, 06:48 PM   #10
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Dude, you're harshing our mellow. Chillax.
Old 10-24-2010, 06:51 PM   #11
ddongbap
Just yours perhaps? Cause it ain't harshin' mine.
Old 10-24-2010, 07:43 PM   #12
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
It had to be said. I mean come on, doesn't slow down come to everyone's mind first after they read that? Is it really that hard a thought?
Colin Chapman disciple
Old 10-24-2010, 09:49 PM   #13
Altitude
Altitude's Avatar
I have lots of thoughts while reading posts around here. I don't always put them in a post...
The last thing we need is all the "hardcore" auto junkies coming here to insult people who have a genuine question no matter how silly some may think that question is.
Old 10-24-2010, 10:03 PM   #14
why?
why?'s Avatar
Drives: Yaris LB
lol! hardcore? not sure anyone truly hard core would take the time away from wrenching to post on a message board, but that may just be me.
Best all-season tires for the Yaris? Rahxephon Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 03-17-2013 06:40 PM
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 06:58 PM
2007 Yaris bad tires weaver615 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-27-2010 07:21 AM
Brown Tires and Squealing Brakes captainm27 General Yaris / Vitz Discussion 14 10-22-2009 12:18 PM
