#1 |
![]() ![]() Drives: Red 3 Dr HB 2008 Auto. Join Date: Feb 2009
I have a friend who work to the same dealer where i bought my car and he told me that the cruise control Toyota installed in my car had a problem and Toyota remove the cruise control.
He told me that my name was in the list. He didn't know enough about that to explain everything but only that there are a recall and Toyota remove them from the car for now. ![]() *The cruise control has been install by the dealer. *Update* http://wwwapps.tc.gc.ca/Saf-Sec-Sur/...chResult&pg=-1 Last edited by Maxh91; 10-20-2010 at 09:22 PM. |
![]() ![]() ![]() Drives: 2010 Carmine Red hatchback Join Date: Mar 2009
Was this factory installed or did the dealer install it when you bought the car? Either way, it sounds odd that they just removed it from your car. Did they compensate you or anything?
#3 |
The dealer installed it after i bought the car. Looks like they remove the cruise control for the moment and when they find a fix, they install a new one. I can't find information about that recall on the internet.
Edit: The dealer, not Toyota |
#4 |
Interesting. I suppose there was an issue with the aftermarket units, although I'm not sure what that could be. As long as they reinstall a "good" one later then I would have no problem with that. Although if it takes a long time to fix I would try to get something for the inconvenience/
Good luck and let us know how it gets resolved. |
#6 |
toyota
Drives: 2007 Yaris RS Blazed Join Date: Oct 2006
this recall is not that bad ..you dont have to have it taken off.. its only if ur using a 2 way radio in the car..which i never do..but worst come to worst it says it fluctuates your revs while using a 2 way radio..
although you can have them take it off and get your money back and but an after market for a lot cheaper cost..i believe its $450 cnd to have that on..do the diy that cost less than $20 buck then ur up by the difference.. |
#7 |
If they change the cruise control, i would remove it but if its is only an interference problem, i keep it. I hope they change it...
#8 |
![]() ![]() ![]() Drives: 2008 Yaris 5 speed HB Join Date: Oct 2008
Thanks for posting.
I bought that same unit and installed in myself here in the states. While I don't think the 2-way radio interference problem will affect me, I might take some time to put a metal shield around the unit the next time I do some work under the dash. |
#9 |
![]() ![]() ![]() Drives: 07 Yaris Sedan, Auto Join Date: Jun 2010
i have the exact same rostra cruise installed on my 07 auto sedan and it has worked flawlessly.
#10 |
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
I've used mine for thousands of miles with zero issues. This sounds like it would be of concern for taxi, commercial or emergency vehicles Yarii. Not an issue for most of us.
EDIT: My letter from Toyota Canada arrived in the mail yesterday (Oct.20). As I don't use two way radios I'll disregard this recall as they're not offering any corrected replacement, but rather a refund, which won't control the speed of my car.
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
#11 |
I got the letter for the recall in the mail. It says Toyota and Rostra have done investigations and there is no safety issue. They simply recommend we have it removed for a full refund in order to retain our confidence or something other in Toyota. It says if we choose not to have it removed, to avoid using 2-way radios.
Funny thing is, it's not just using a 2-way radio, it's using them at specific frequencies AND in close proximity to the rostra unit. I'm hoping I can get them to remove it and install the OEM stalk. If they won't, it stays. The ~$500 would be nice to get back but I do too much highway driving to do without my cruise control now. |
#12 | |
#13 |
I just got an email back from the dealership. They say if I choose not to have it removed they need to have it recorder with a signature on one of their work orders.
The response said they OEM cruise is not available to them for installation. I don't know if that means they won't install it or if they can't get the part at all. ![]() I'll probably get them to remove it (and replace the plastic around the steering wheel) and install the cruise on my own. Will still come out ahead. The cost to have this one installed was far more than I think it was truly worth. |
#14 |
Drives: Yaris Hatchback 07 Join Date: Oct 2010
When I bought the 07 Yaris - a 40,000km lease-back, I had the Rostra installed. It worked fine for about 6 months, then demonstrated the pattern that the recall note described and it cut in and out, would change speeds erratically and would die for long periods of time. The dealership spent a lot of time on it at no cost to me. No difference. I'm going to take them up on their offer to remove it, pay me back, then get another installed. I need a cruise control!
#15 |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
here in the states my wife's Rostra intermittently doesn't work, she'll set it and it will just cancel itself (stop holding a selected speed) or she will try to set it and it won't do anything...
#16 |
Occasionally ( perhaps 1 in 20 tries) mine will not take a set. I switch it off, then on again and it sets fine.
#17 |
![]() Drives: 2008 yaris 5door RS Join Date: Nov 2008
I have the rostra cruise unit. I'm keeping it. when we bought the car, I was actually a salesdick at the dealership...so on paper i sold the car to my wife...
it was a $489+tax option, we wanted cruise, and it was the only cruise option that would work with the warranty, so we got it. at the time, may 2008, there was no factory cruise option, only the dealer installed option. we use it constantly on the highway. so, I'm a Firefighter and Medic, and i actually do carry and use a 2way vhf radio, and when i'm driving, i typically stick it in the driver's cupholder...which i've been warned against doing. the catch is, according to the letter, it's only susceptible to interference when the radio is in transmit mode. i never transmit when it's sitting in the cupholder, and also according to the letter, it's only a possible scenario when the cruise is activated. when i'm on the highway, leaving my community, i'm no longer on call, so my radio is off anyway. the reason i'm keeping it, is because i feel the reaction from the dealership has fell short. unlike others, the only option for the "recall" (it's not a recall if all they are doing is removing it and not replacing it), is for them to remove it free of charge. no refund was offered, and it was not an option when i inquired. they will also not install a cruise unit in it's place, so it really does sound like a great deal, doesn't it? I'll chance it, but like i said, using my radio and using my cruise will not coincide. the car is at the stealership right now getting it's 65,000 km maintenance service, front brake service, and acc belt replacement. they told me i'd have to sign a waiver saying i didn't want it removed - i'm going to refuse to sign it, based on my lack of support of toyota's decision that i don't need cruise control. |
#18 | |
Just brought my car in today to have my winter tires removed and get an oil change. Turns out the reason they left the old cover was because the part wasn't available then and they put a new one on . I've got OEM cruise now (thanks to CTScott and others in the DIY forum) and no hole.
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| Cruise Control on 2010 Canadian Manual | Kaya B. | DIY / Maintenance / Service | 25 | 10-01-2010 03:31 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
