Old 10-22-2010, 02:05 PM   #1
matthewai
matthewai's Avatar
Drives: it is kinda stock
e-brake abyss...
there is a small gap where the e-brake goes into the middle console on my 2010 yarii sedan it eats change and lighters i tried taking the bolts off in the compartment but could not locate the missing objects. would the leather e-brake boot solve this problem and does the console have to come all the way off to install? is there any secondary clips or screws that allow the whole console to come off?
Old 10-22-2010, 07:38 PM   #2
Mittelklasse
Problem, officer?
Mittelklasse's Avatar
Drives: '06 Yaris 5DLB 1.5
I don't know whether the hatchback's shifter console is identical to sedan's or not.
On my HB, there's only one screw in the cupholder behind the handbrake, and two clips under the center console.
To remove the clips, you just run your finger under the plastic trim on the side of the footwell, and lift up straight.
Do this on both sides.
Speaking of eating coins, I used to have that problem to.
A coin fell into my steering wheel and makes a clanking noise every time I turn. (That's what you get for paying tolls with coins )
Quite a hassle to get it out, but I don't want to get shot in the face by a coin when the airbag explodes.
Mittelklasse is offline   Reply With Quote
Old 10-22-2010, 07:40 PM   #3
chrisj
Hooch Brewer-Shine Sipper
chrisj's Avatar
Drives: 2009 5-dr LB
chrisj is offline   Reply With Quote
Old 10-22-2010, 07:46 PM   #4
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Hopefully someone will answer your question who has hand the leather e-brake installed.
I have the same problem as yours and did pick up the leather e-brake from MicroImage because the rubber flap had torn off. Hopefully we both will get some answers either tomorrow or Sunday if not from a reply here.
Old 10-22-2010, 09:01 PM   #5
Here's how the sedan console comes apart. The 3 pieces just pop off and then you have four screws.
Name:  Sedan Console.jpg
Old 10-22-2010, 10:43 PM   #6
kimona
kimona's Avatar
Drives: 2014 White VITZ
CTScott FTW! A wealth of technical information.
Old 10-23-2010, 02:47 AM   #7
matthewai
matthewai's Avatar
this is great ct bigg ups and yes the boot is on the way along with some other stuff i ordered
abyss, boot, e brake, middle console
Done! D2 Brake System, Tein Springs and H&R Wheel Spacers Installed RedVitz Photo-Video-Media Gallery 18 10-09-2010 03:36 PM
DIY For radios that require attaching a wire to parking brake Slick DIY / Maintenance / Service 0 04-16-2009 08:14 PM
