Old 11-30-2010, 05:00 PM   #1
Hood pins!
Jason inspired me (thanks for the pics sir), so I tackled hood pins (thanks for the help JR!), hacking up my favorite hood to do it. I removed all the hood latch parts from the frame, and the "catch" from under the hood. A little cleaning up to do but they work perfectly.
I like 'em:
Old 11-30-2010, 05:06 PM   #2
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
B E A utiful!
Old 11-30-2010, 05:25 PM   #3
Klink10
Klink10's Avatar
Clean
Old 11-30-2010, 06:04 PM   #4
TickleTimeTim
Free Mustache Rides
TickleTimeTim's Avatar
Drives: 2007 Yaris HB
very sharp
Club SHIFT
Old 11-30-2010, 07:04 PM   #5
Jason@SportsCar
I like 'em:
Once you get past drilling the first hole it gets easier.
I would have thought you'd be sporting the carbon set : http://www.coastfab.com/images/pdf/AeroCatchUpdate.pdf
Old 11-30-2010, 07:08 PM   #6
^ I don't do carbon "look"
Old 11-30-2010, 07:12 PM   #7
Jason@SportsCar
That battery under your hood says otherwise.
Old 11-30-2010, 07:15 PM   #8
haha, good point. Except I think Braille uses real carbon?
I could NOT get those pins to fit until I bent the brackets about 10 degrees. I think my hood must have a little more angle than yours.
Old 11-30-2010, 07:23 PM   #9
Jason@SportsCar
haha, good point.
I may have forgotten to mention, but it is in the instructions, you notch out between the side and bottom hole to get the pin to line up.
Hard to see in this image, but the small piece of plastic that separates the front side and the bottom hole has been removed, to allow the pin to enter strait.
Old 11-30-2010, 07:27 PM   #10
Jason@SportsCar
Take one apart. We had the "6lb" carbon unit in a past project car, the "carbon" case added 1lb to the 6lb battery. Lots of plastic and clear coat hiding the standard Braille case.
There are not to many parts out there that I would consider real carbon... Almost all of it is one tiny layer over a fiberglass or plastic base. The real stuff is so expensive.
Old 11-30-2010, 07:43 PM   #11
TEHxFALLEN V1.2
TEHxFALLEN V1.2's Avatar
Drives: '08 Lexus IS-F
No problemo!!
Sponsored by: Micro Image
http://microimageonline.com
Old 11-30-2010, 07:54 PM   #12
JBougie
JBougie's Avatar
That the cleanest hood pin setup I have ever seen. I really like that!
JBougie is offline   Reply With Quote
Old 11-30-2010, 07:59 PM   #13
Jason@SportsCar
They are durable to... Both held strong during this hit, and were transferred over to the replacement hood.
Old 11-30-2010, 11:15 PM   #14
I see where you trimmed it (um, and yeah you forgot to mention it ). The kit comes with directions? oops.
I considered doing that and chickened out. The slightly angled brackets worked out ok.
Old 11-30-2010, 11:45 PM   #15
Jason@SportsCar
Well I did send you the pic with the notch taken out.
Old 12-01-2010, 01:01 AM   #16
severous01
when i saw 'hood pins' i came in to make fun.....but dam. that's freakin awesome.
very clean, neat install, nothing like the big goofy chrome rings with pins and goofy key rings.
those are some hood pins i'd actually use. i wouldnt mind using. from a 100hp car to a supercharged, 10-second street car to a 8 second strip only car.
hood lift? Qmobile Cosmetic Modifications (Exterior/Interior) 19 08-14-2010 09:35 PM
C-One Replica Hood. Lets Fix this sucker! TinyGiant Cosmetic Modifications (Exterior/Interior) 56 11-09-2009 11:31 PM
Micro Image Hood Design Contest cali yaris Micro Image 209 10-04-2009 02:49 AM
Installed hood deflector, in-channel vent visors and hood seal. IsLNdbOi Cosmetic Modifications (Exterior/Interior) 16 12-20-2008 08:36 AM
Before you buy . . . check that hood! woof General Yaris / Vitz Discussion 4 12-02-2006 05:14 PM
