Old 12-07-2010, 07:39 PM   #1
Midnight Drifter
Going Retro
Drives: '09 Tacoma | '90 Tercel
Warning light removal/replacement
I'd just like to know what the process is for getting into the instrument panel and pulling out/changing the warning lights. I'll be getting a 2nd set of wheels soon and I don't need an inaccurate (and expensive) TPMS because I check my own damn pressures every time I go out for a drive, and would like to pull the warning light so it doesn't annoy me.
Midnight Drifter is offline   Reply With Quote
Old 12-07-2010, 08:33 PM   #2
auxmike
auxmike's Avatar
I was going to prop up a small Domo in front of my light..
I too would like to snuff out that light..
Old 12-07-2010, 09:28 PM   #3
Check out my DIY on disabling the indicator. It's easier to do it at the TPWS module then to do it in the cluster.
http://www.yarisworld.com/forums/sho...light=tpws+diy
Old 12-12-2010, 01:45 AM   #4
Midnight Drifter
Going Retro
Well, not for nothing, but down the road I also plan on doing an a-pillar gauge and that'll probably set off an airbag light when the original is removed... so it's better to know now how to just remove the bulbs. :P
Old 12-12-2010, 07:34 AM   #5
Removing the A-Pillar cover won't make the SRS unhappy (unless you disconnect the side curtain squib and turn the ignition on with it disconnected).
Here's a thread about how to change the color of the LEDs in the cluster that shows the details of removing and taking apart the cluster. All of the indicators are LEDs, so removing them means desoldering.
http://www.yarisworld.com/forums/sho...r+color+solder
SRS warning light - any guesses? Goose DIY / Maintenance / Service 15 03-24-2014 01:57 AM
How do you reset the TIRE PRESSURE WARNING LIGHT penny09 DIY / Maintenance / Service 3 09-26-2010 02:53 AM
SRS warning light and dealership fun :) wsladaritz General Yaris / Vitz Discussion 16 09-18-2010 04:37 PM
Washer fluid warning light "Backwards" Snyprwlf47 General Yaris / Vitz Discussion 2 02-15-2010 08:47 PM
