Old 12-27-2010, 08:50 PM   #1
CueBall
Ruler of the free world
Drives: 09 Yaris 2D HB
BASIC remote entry questions
I have read the posts here about remote entry insallation. Also reference Dan Q's page (see here):
http://home.comcast.net/~dquicker1/s...ess_Entry_DIY/
I have the Viper 211HV. Connects exactly like the Valet 712T (same color wires for same connections per Dan Q's) Perhaps these are both made by Directed electronics?
That being said, mine also has several other wires not lised in Dans install. (see skipped/missing numbers in Dans wire harness H#'s) Probably because they aren't used.
That's where my questions come in...
1. Horn, lights, lock, unlock; should ALL output signals be (-) negative/ground/earth for the yaris?
2. Is it necessary to connect the H1/7(lock GND) and H1/9(unlock GND) to ground? Wouldn't this be handled by the H1/11(GND)? Note: there are no special ground wires for the horn or lights.
3. Lastly, I do not want/need to do programming and ignition controlled door un/locking. So, is there any need to wire the H1/15 ignition wire? (other than those two features.)
Basicly, if all I want to do is lock and unlock with the keyfob, do I need anything more than H#'s 1-5-8-10-11-12?
I dont want to tap more wires than I really need. Thanks.
CueBall is offline   Reply With Quote
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
What is needed to add a second keyless entry remote? teddy DIY / Maintenance / Service 13 12-28-2010 09:49 PM
Power door lock keyless entry and remote start rizaydog In Car Entertainment + Electronics (audio / video / alarm) 10 07-20-2009 04:14 PM
How to check if Yaris has remote entry fraenx DIY / Maintenance / Service 19 07-10-2009 11:33 PM
Should I add remote key less entry? Options YotaYarisUSA General Yaris / Vitz Discussion 13 05-02-2006 05:06 PM
