Old 01-12-2011, 07:29 AM   #1
mongezim
Drives: T3
Child lock stuck
I've been struggling for the past 3 weeks to open my (passenger) back door the child lock jammed from outside and inside cant use it at all, any advice please!
mongezim is offline   Reply With Quote
Old 01-12-2011, 09:31 AM   #2
If you can't open it from the outside (with the unlocked), then it is probably not the child safety lock, but rather the lock cable that is bound or broken. You need to get the inside panel off to check it out, but it is very difficult to remove without making a mess when the door won't open.
Old 04-22-2011, 07:57 PM   #3
lopsie100
Drives: 2004 Toyota Yaris
hello, well my right side passenger door is locked from the inside. It won't let me open from the inside. I can open from the outside without using my key or the remote. This is very uncomfortable for my passengers.. Any thoughts?
lopsie100 is offline   Reply With Quote
2007 Yaris Door Lock Issue bhola General Yaris / Vitz Discussion 7 10-05-2010 12:01 AM
Driving wheel doesn't lock when taking off the key Pingouin General Yaris / Vitz Discussion 5 09-08-2010 11:15 PM
Is this normal with the Yaris steering lock? STC General Yaris / Vitz Discussion 13 07-06-2010 10:15 PM
Help! MES power lock install question mr_thunder16 DIY / Maintenance / Service 5 11-13-2009 08:50 AM
DIY: Changing Factory Door Handles and Lock Cover redyaris DIY / Maintenance / Service 10 05-19-2007 05:55 PM
