#1 |
AKA Samurai Racer
tire size change advice needed
hey guys
i have a 1800 TS , looking to change tires to this setup OEM - 205 / 45 / 17 new setup - 205 /40 /17 any ideas on the change ? i know it will effect the speedo a little , but you guys recon its safe enough ? |
AKA Samurai Racer
?? anyone ?
#3 |
![]() Drives: 2004 Corolla Join Date: Jan 2011
safe? sure, you'll be going slower than the speedo says so.
#4 |
i agree. but at least he'll also be 10mm lower...
#5 |
Drives: 2014 White VITZ Join Date: May 2007
The TS stock suspension is already a bit lower than the stock suspension on US version cars. The 205/45's are a very good fitment on the TS. Yes, 205/40's will fit without issue; however, what would be your rationale for going with a shorter tyre?
#6 |
AKA Samurai Racer
hey guys thanks for the advice , yeah , its gonna make the fender gap bigger , currently im running a Tein spring kit , attached is a pic of how it sits
my reason for going to 40's is cause it is alot cheaper , the 45's cost R1300 , the 40's cost R700 , thats about half the price .. so thats my thoughts ... mmmm |
#7 |
AKA Samurai Racer
the car actually sits a little lower than in this pic , its more on the wheels , will try take a better pic tomorrow
#8 |
AKA Samurai Racer
also , wont the 40's have better handling ?
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
I ran 205/40/17's with no problem. Go for it.
#10 |
AKA Samurai Racer
what drop you have on the car ?
#11 |
Tanabe DF210's that are clamped to be lower than normal. Around 2.3" in front I would say?
#12 |
AKA Samurai Racer
ah ok ... i must say , im very hesitant to put on the 40's , 10mm drop is quite a bit on a already tein drop kit
#13 |
If the 45's are working well with your suspension mods, then I'd stick with that size.
#14 |
AKA Samurai Racer
yeah , i recon i will stick to OEM specs for now , got a set of Yokahama R1's in mind that are well priced at R800 each.
#15 |
![]() ![]() Drives: Yaris SR 1.8 Join Date: Sep 2010
How do you like the Teins? I just ordered a set yesterday plus a TRD sway bar. They say they give 30-35mm drop, would you say that is accurate? 'Cos I just measured the stock gap from my wheel to my arch and I've got 60mm, looks like a monster truck.
#16 |
AKA Samurai Racer
you gonna love the s-tech ! yeah , its about a 35mm front , 30mm rear , but becuase the TS has a slighly heavier motor setup , it seems a little lower , looks great. it should take it all the way on to the wheels , provided you running the OEM size tires
#17 |
AKA Samurai Racer
thanks for the Feedback ;-) ... im thinking of going with the Red's , want full adjustment ;-)
| URGENT Advice Needed! Relating to Power Steering, Alternator and Electrical. | The Marshall | General Yaris / Vitz Discussion | 25 | 10-21-2010 08:23 PM |
| Quick advice needed on unfinished amp install | GreenSpeed | In Car Entertainment + Electronics (audio / video / alarm) | 15 | 01-15-2009 11:03 PM |
| Tire size? | JDMVitz | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 03-21-2007 11:03 AM |
| Need help with wheel & tire size | rwseattle | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 12-12-2006 01:10 PM |
| The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 07:09 PM |
