Old 03-18-2011, 11:03 AM   #1
Lil Abner
Drives: 2009 3dr LB Manual
Rear Washer Nozzle??
The rear washer spray nozzle, is it suppose to spray like the front ones? Mine just sends a stream straight down the window. I guess I'd like to know what it's suppose to spray like to determine if I should replace it.
Thanks in advance!
Old 03-18-2011, 05:12 PM   #2
the_boss
the_boss's Avatar
Drives: 07 YARIS HATCH 5 DOOR
Send a message via MSN to the_boss
I saw something somewhere here that the rear one will not spray like the front one, it just drops water on the surface of the window.
the_boss is offline   Reply With Quote
Old 03-18-2011, 10:05 PM   #3
sex
sex's Avatar
Drives: 09 5DR
you're ok; it just dribbles down the glass. there's no adjustment available
Old 03-19-2011, 10:46 AM   #4
Lil Abner
Well, I was hoping someone would tell me I needed a new one! Does anyone know if a sprayer from the front will fit on the back?
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
Rear Washer Jet ronsolostar DIY / Maintenance / Service 0 09-23-2009 03:21 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
Rear window washer - liftback boris13 DIY / Maintenance / Service 24 06-05-2007 04:20 PM
