#1 |
Can you put 195 60 15 tires on 185 60 15 rims?
Hey peeps,
Just wondering, is it safe to put 195 60 15 tires on 185 60 15 rims. I need some new rubber and for some reason 195 is cheaper than 185. Thanks
![]() "Manual labour is not for me. In fact i'm not even sure non manual work is either." -Anthony Linton Check out ▬▬► I like I like ◄▬▬ for more fun on Facebook |
When you look at tires, the manufacturer will list the rim widths that are compatible with a particular sized tire (5.5", 6", 6.5", etc.)
#3 | |
ps we run metric here
#4 | |
Just multiply by 2.54... Actually, pulling up an example on TireRack.com, I see that a 195/60 R15 will work on a 5.5" to 7" rim, so the simple answer to your question is: Yes a 195 is fine on a 185 spec rim. You will increase the tire height by 12mm with a 195/60 vs a 185/60.
#5 |
![]() ![]() Drives: toyota Join Date: Feb 2011
yes u can but 195 is taller then 185 oem
#6 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 black yaris Join Date: Oct 2010
^not much.^ maybe a mm.. 195 is wider then 185
#7 |
![]() ![]() Drives: '10 3D Liftback Join Date: Mar 2010
195/60/15 is taller than 185/60/15
195/55/15 is a tiny bit shorter than 185/60/15 195/50/15 is significantly shorter than 185/60/15 May vary slightly by brand. |
#8 |
Drives: 2014 White VITZ Join Date: May 2007
195/60/15's will fit the stock wheels very well... and IMHO the 195/60/15 is a better fitment than the original 185/60/15.
#9 | |
I think I've got myself a decent deal. $80 a tire including fitting and balancing. Then the front end alignment is gonna be $55. Tires are not a brand name but look like these MICHELIN XM1+
#10 |
![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
If both are 60 tall, how on earth could the 195 be 12mm bigger? I can see wider because it's 195 instead of 185..but both are 60 in height
I live my life a quarter pounder at a time. And for those 500 calories or more, I'm free. I need FRIES! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didn't blow the seam on your nugget box. There she is, 2 pounds of pure beef. My dad ate it in 9.0 seconds flat. Check it out, it's like this. If I lose, winner takes my happy meal. But if I win, I take the burger and the toy. To some people, that's more important. |
#11 |
Drives: lil red 5-door Join Date: Sep 2006
The "60" part is a percentage... really weird system, tires are measured in centimeters, percents and inches
Basically the actual height of the sidewall is 60% of the width of the tire (the 185/195 part).
The price of freedom of religion, or of speech, or of the press, is that we must put up with a good deal of rubbish. - Robert Jackson ![]() Bye bye 1NZ... |
#12 |
![]() ![]() ![]() Drives: 07 Yaris Sedan, Auto Join Date: Jun 2010
op, i have 195/60r15 on my sedan. they are approx 1.98% too tall so the speedo will be slightly off and your odometer will read 1.98% too few miles.
to compute mileage you must multiply the miles driven by .0198 to come up with the actual miles before you divide by gallons used. |
#13 |
Thanks everyone for you help on this issue. But I now have 4 185 60 15 and could not be happier. Mods please close this thread.
| 18" TRD Rims and Pirelli Tires FS | AlphaFox78 | Items for Sale by private party | 38 | 10-14-2010 12:54 PM |
| Rims and tires on craigslist for 350 for bay area members | YarisSedan | California | 0 | 01-12-2010 01:21 AM |
| FS Brand New Stock rims w/ Tires | FlintS | Items for Sale by private party | 10 | 09-24-2007 08:22 PM |
| Rims & Tires | riceboy | Items for Sale by private party | 19 | 11-25-2006 12:22 AM |
| New rims - old tires | littlecarlove | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 11-15-2006 06:51 PM |
