Old 04-10-2011, 05:57 PM   #1
jonathankoji
jonathankoji's Avatar
Drives: 08 Yaris S Sedan
Lightbulb White lights
I know there's a lot of topics regarding headlights, but all I'm looking for is a plain white light. I don't really care about improved visibility (as long as it's not worse than OEM) and I'd prefer not to deal with HID kits (unless it's more cost effective) and I'm not brave enough to even consider retrofitting.
A lot of people online suggest just going HID but I don't need drastic light output and I don't want to blind other drivers.
I just want pure white light that will last, unlike the Silverstar Ultras I've read about.
Is there a viable solution or am I being unreasonable?
jonathankoji is offline   Reply With Quote
Old 04-10-2011, 11:30 PM   #2
can't have your cake and eat it too
Old 04-11-2011, 12:16 AM   #3
jonathankoji
Darn, I was afraid of that
So, the weakest HID is probably the best way to go?
Old 04-11-2011, 12:17 AM   #4
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
I have 2 toyota cars, one it's all HID, the other one Silverstar Ultras, Yes HID is 5K and pure white compare to the S.U. Wonder for better vision... Silverstar Ultras are better, If I had to do it again, I wouldn't go with HID, rather adding some speed lights instead.
D.
CLA 250, 4MATIC
Old 04-11-2011, 12:26 AM   #5
jonathankoji
Any more info on the speed lights? Google keeps bringing up photography lightslol
Old 04-11-2011, 12:36 AM   #6
derickveliz2
Exclamation
I really want to get them for my Yaris (They are in my "Wish Lits" for sure) (LINK)
D.
CLA 250, 4MATIC
Old 04-11-2011, 12:49 AM   #7
jonathankoji
D.
Old 04-11-2011, 12:55 AM   #8
jonathankoji
Any recommendations from these?
Old 04-11-2011, 08:20 PM   #9
RedRide
RedRide's Avatar
Any aftermarket hyper white headlight bulb is not going to last as long as stock.
Also, don't get a bulb with a color temp above about 4,000k or you will get reduced visability.
Personally, I use "PIAA Xtreme White Plus H-4" bulbs They are 4,000k and emit a bright, much whiter light than stock. They are a great compromise between a white light and visibility.
They also seem to last well over a year, depending on use of course.
Old 04-11-2011, 10:13 PM   #10
severous01
sylvania long life factory replacement
hella long life factory replacement
osram long life factory replacement
see a thing goin on here...
or, you can go HID. as long as you're not going with a cheap knock-off of a single HID with a halogen high beam you should be fine. a dual filament HID or any kit that uses either the sliding shield or moving bulb to create the high should be fine. GARM offers a kit that's a single HID bulb with a moving shield for 89 bucks. i'd get that and i do plan on it in the near future.
stick with 5000 or 6000k.
Old 04-11-2011, 11:51 PM   #11
jonathankoji
Good point
But won't that throw light/glare everywhere since it's not meant for a halogen reflector bowl?
Old 04-12-2011, 05:35 PM   #12
severous01
the ones with the shield is designed for a halogen replacement
also, they make them now with dual filament. they're more expensive, but also more reliable. they have 2 ballasts, 2 sets of wires, and 2 full active filaments. they're the best designed, and best working. they're actually designed to put light where the light was meant from the factory. but, you also have 2 ballasts to locate, and 2 pairs of wires to run into the headlight assembly.
a guy in my shop has a set. he paid 295 bucks. he ran them properly (as he is an auto tech) and 2 months later one of his ballasts failed. the company only warranted the bulbs, so he uninstalled them. i'd have jumped on it if he would have taken less than 150 for it, but he wouldnt go less than 200. so....i'm stuck with halogen now. i'm going with the $89 unit from garm. one ballast, one bulb, and an extra wire to move the shield when i want highs...which i never use any way. there's a pic somewhere on here with a white car that runs them. the beam pattern is flawless and looks factory.
Old 04-13-2011, 01:22 AM   #13
jonathankoji
Yeah I never use high beams either
This
kit is the one you're talking about? I see the shields you're talking about. Do you know if these are 35 or 55w ? Seems like 55 would be overkill.
Also, 295$ sounds crazy high for a set of failed ballasts 2 months later.
Yarisworld Decal -SHOW YOUR YW PRIDE!! Astroman Items for Sale by private party 235 08-21-2019 10:45 AM
Fog lights, or parking lights stopped working sylvermagyk DIY / Maintenance / Service 4 03-24-2011 05:13 PM
Taillights, signal lights, parking lights stop working jamal1984 DIY / Maintenance / Service 2 10-13-2010 10:17 AM
white yaris; white wheels? botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 02-07-2009 10:20 AM
So Hasher now has a sexy ride...... hasher22 Photo-Video-Media Gallery 15 06-09-2007 07:33 AM
