Old 04-12-2011, 10:53 PM   #1
Yaris79
Drives: 2009 Yaris
Radial Pull?
I have a 2009 Yaris. I am trying to find the problem that is causing it to feel "off" it feels like it leans but I am hypersensative to change. I think it was doing it a little before I got an alignement and new tires and now more so. I notice it mostly when changing lanes and turning corners. The two front tires are new and have 600 or so miles on them and the back two tires have 50,000 miles on them. Could this be radial pull? Input would be helpful as would a suggestion of a place a might go to in the metro atlanta area for good advice that want charge me like crazy.
Yaris79 is offline   Reply With Quote
Old 04-12-2011, 11:18 PM   #2
RedRide
RedRide's Avatar
OK..... you got two new tires on the front so, you are most likely getting "tread squirm" that you may be interpeting as leaning.
The tread squirm that is present in most new tires is not that noticable if you replace all four at once but, it can be a problem if you only replace the front.
Old 04-12-2011, 11:18 PM   #3
severous01
as long as the tires are the same on the same axle it shouldnt matter
if it doesnt pull dont worry about it. you should adjust to the car, not the other way around
Old 04-13-2011, 06:38 AM   #4
nemelek
DWEED
nemelek's Avatar
There is a lot of tread difference between 600 and 50,000 miles. Get more new tires and see what happens.
Old 04-13-2011, 08:30 AM   #5
SailDesign
Drives: .
What he said ^^
Is this the same issue from your other thread? If so, then the answer is undoubtedly that you have worn tires on the back, sticky on the front. Get more new tires, less new threads.
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
Had my brakes done....now handbrake is harder to pull. captainm27 General Yaris / Vitz Discussion 7 05-10-2010 07:00 PM
WTB: roof pull covers cali yaris Willing to Buy by private party 6 09-17-2009 08:30 PM
Engine Pull Anthony_kp61dotnet Performance Modifications 12 03-11-2009 07:13 PM
Leaf Blower Turbo-Dyno Pull Black Yaris Forced Induction Forum 9 06-20-2007 11:53 AM
