Old 04-20-2011, 07:27 PM   #1
skootdog
skootdog's Avatar
Drives: 2011 White A/T
TPMS ?
How do you make the TPMS light disapper? Is there a fuse or wire I can snip to disable it? What happened to checking your tires every week or so?
"Because it's Racecar"
skootdog is offline   Reply With Quote
Old 04-20-2011, 07:41 PM   #2
^they're checked every time you drive now.
I don't have a Yaris, but last time I was in a car with TPMS there was a button that you'd push in while you turn the key on. I had to hold it for like 10 seconds and the light was reset. This was back in '99 though so I don't know if the setup has changed.
Old 04-20-2011, 07:54 PM   #3
skootdog
skootdog's Avatar
I just found how to disable it in the DIY section! I'm about to put new wheels on my car and just wanted too know if there was a way. New sensors are xpensive!
Old 04-29-2011, 09:33 PM   #4
MitchReeves2967
Drives: 2010 Toyota Yaris Sedan
Is it true that if I get 15" wheels I can still use my stock tires and tpms, even though my stocks are 14"?
MitchReeves2967 is offline   Reply With Quote
Old 04-29-2011, 11:16 PM   #5
sex
sex's Avatar
Drives: 09 5DR
you can reuse the tpms but not the tires; tires just won't fit
any tpms swaps out there? steel to aluminum? severous01 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 03-26-2011 07:10 PM
Tire rotation: Does TPMS recognize tire position? jcdrotos Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-17-2011 02:00 PM
DIY - - -TPMS work around rningonfumes DIY / Maintenance / Service 6 03-03-2011 08:11 PM
tpms compatibility? bwong2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 07-11-2009 09:33 AM
TPMS Gauges - do they exist? Sodium Duck DIY / Maintenance / Service 24 03-01-2009 12:18 AM
