Old 05-09-2011, 03:07 AM   #1
Spahrticus
Spahrticus's Avatar
Drives: ///M3, Yaris
Run fog lights off headlights?
Is it possible? Just splicing into either headlights or corner lights? Don't care much about OEM performance at this point.
Spahrticus is offline   Reply With Quote
Old 05-09-2011, 06:20 AM   #2
You still need to wire them through the fog light relay, as just paralleling the fog lights with the headlight wiring would be too much current draw for the headlight circuit. After you make the connection through the under hood fuse box and insert the fog light relay in the OEM position, you can jump the switch side of the fog light wiring to the switch side of the headlight wiring to make them come on with the headlights, and not have a separate switch.
Old 05-09-2011, 07:31 PM   #3
Spahrticus
Spahrticus's Avatar
What wires would I have to mess with to accomplish this? And this is on the D4 connector under the steering wheel, yes?
Old 05-09-2011, 09:04 PM   #4
On Connector D4, to make them just come on with low beams, jump the wire in pin 3 to the sky blue wire in pin 8 (next to the pink wire). To make them come on with both high and low, jump the wire in pin 3 to the wire in pin 13.
FOG LIGHTS phenoyz77 General Yaris / Vitz Discussion 6 01-27-2010 05:22 PM
my Projector Fog lights project ezhacker1 Cosmetic Modifications (Exterior/Interior) 3 01-10-2010 05:21 PM
Fitting Front Fog Lights OEM - Yaris 2007 3dr weller Cosmetic Modifications (Exterior/Interior) 1 12-17-2009 12:29 PM
Need Help Wiring Fog Lights MadMax Cosmetic Modifications (Exterior/Interior) 29 11-29-2008 06:31 PM
Fog lights for S sedans (US version) paeko73 General Yaris / Vitz Discussion 11 07-02-2006 11:38 PM
