Old 05-16-2011, 05:02 PM   #1
ecc_33
ecc_33's Avatar
Drives: 2008 toyota yaris
Code P0171
This code pops up now and says its a System too lean bank 1. It started throwing this code right after i put that inline husky air compressor filter on the hose that comes off the valve cover. Is this my problem or is it the up stream 02 sensor?
08 toyota yaris with some big tires lol
02 chevy duramax that runs 11.63 at 116 mph in the 1/4 mile
ecc_33 is offline   Reply With Quote
Old 05-16-2011, 05:15 PM   #2
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
I've heard the hose run to the filter may be compressing under vacuum...what kind of hose are you using?
-Type 07 FFL-
My odometer 03/11
Old 05-16-2011, 05:36 PM   #3
ecc_33
ecc_33's Avatar
im using the stock hose. Just cut enough out to install the filter. I know at idle it runs rough real rough. When you clear the code it will stay out for about 25 miles then come on again. I just wondered if it was the filter setup or not. I gutted mine. Took the filter inside the bowl out and used the rite stuff on the bottom drain valve cause it was leaking bad. Maybe that drain bowl is still leaking? Seems like everything else is good. I wouldn't think it would colapse the stock hose but could be possible
Old 05-16-2011, 05:39 PM   #4
mazilla
advocatus diaboli
mazilla's Avatar
I wouldn't think the stock hose would be the issue either...
Is the filter on in the right direction? (I had to ask) If you remove the unit completely, do you have the same problem?
-Type 07 FFL-
My odometer 03/11
Old 05-16-2011, 05:50 PM   #5
ecc_33
ecc_33's Avatar
yeah the arrows on the filter head point to the throttle body. I haven't takin it off cause i don't have a stock hose now
QR Code Window Stickers nick.dollimount Cosmetic Modifications (Exterior/Interior) 23 02-25-2011 06:22 PM
2010 RS Model Code?? revolution Cosmetic Modifications (Exterior/Interior) 10 10-14-2010 05:11 AM
Yaris CDX 1999 P0171 error code Davax DIY / Maintenance / Service 2 08-18-2010 07:14 PM
error code P0171 bronsin DIY / Maintenance / Service 17 03-12-2010 06:22 PM
P0456 OBD code? jlift DIY / Maintenance / Service 6 09-19-2007 03:28 PM
