Old 05-25-2011, 04:33 PM   #1
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
Another + for MicroImage 23mm Sway Bar.
Got my 23mm Sway Bar today from MicroImage.
First Complaint: All i got is myself no help.
Second, them bolts that hold the shocks together, you will probably need a Impact Wrench Gun to remove it, forget about the sockets with hands.
Took me a good 40 minutes to get everything done, plus while i got the 2 back wheels removed, might as well adjusted my Drum Brakes with Hand Brake.
PROS: Everything, man this is totally worth $164 shipped.
Of course not 100% better, but i said from 40-70% better body roll depend.
Of course not like Porsche but i can tell you probably BMW 3 series feel.
[U]Second[U] Something i do noticed and tested. The coffee will not spill out when i make a turn, normally it's be all over my seat or dash.
The second pic with the navigation and file folder, that is it's originally position after 30 minutes drivie with about 13 turns, normally it's will be on the floor or somewhere else.
I took some pics hope i installed correctly.
Everyone got 200 bucks to spend, add this. And think about it, you drive a yaris everyday why not make it more fun to drive? i mean it's handle better, feel more solid, and kinda easy to install by yourself.
Need input on ULTRA RACING 23MM SWAY BAR VS NITTO REAR LOWER STRUT BRACE. marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 02-22-2011 07:32 PM
Drum howl after installation of 23mm sway bar minnyar Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 04-21-2010 12:57 PM
Which rear sway bar? IsLNdbOi Performance Modifications 46 11-05-2009 06:07 AM
23mm Sway Bar Installed! - Thanks Garm bronzebullet232 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 21 07-19-2009 11:34 PM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
