Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 06-26-2011, 02:14 PM   #1
lammy29
TS 1.8 Version Owners Alloys
To all owners of the 1.8 2ZR-FE with the 17" alloys.
i started to get corrosion near the centre of alloys and bumps so decided to take it into toyota dealer since my car is less then three years old and under warranty. the two back alloys problems are very visible but two in front only slightly.
But good news as the guy inspecting it managed to get the go a head from his boss to order a brand new set of four alloys!! So tomorrow i will have new set of alloys.
I just thought i give you all heads up as supposedly a common problem....
lammy29 is offline   Reply With Quote
Old 06-27-2011, 01:24 AM   #2
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
wow , you pretty lucky , usually the dealers use all sorts of excuses , i never had my wheels long enough to get that , i sold them and got others.
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 06-29-2011, 12:43 PM   #3
Kongo-Otto
Drives: '09 Yaris & '10 Auris
Shouldn't be that much snow in South Africa nor heavy use of salt on the streets.
Old 06-29-2011, 02:46 PM   #4
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
na , not much snow no slat on the roads at all. lucky for us.
JDMtuner
www.jdmtuner.co.za
Old 06-30-2011, 01:46 PM   #5
lammy29
from uk forum
"Yeah when i worked at Toyota we used to change loads of lexus and toyota wheels. As stated above it must be costing them a fortune!! "
"Yep as above if they corrode within expected 'life' your dealer should replace them - Lexus had major problems with the IS200 wheels corroding and are still replacing already replaced one to date - must be costing them a fortune"
"All dealers have to warrant wheels as they should last the life of the car :) aslong as you havent curbed or buckled them"
TPMS Sensors with Toyota Alloys? Lil Abner Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 06-20-2011 11:29 AM
i have a q to US owners FlyingDevil New YARIS Purchase Forum 33 03-26-2009 09:20 PM
Yaris owners in Edmonton,AB 06vitzRS Canada 6 02-20-2009 07:38 PM
READ YOUR OWNERS MANUAL!! MadMax General Yaris / Vitz Discussion 29 12-14-2008 10:38 PM
Will S Sedan Alloys Fit on A Liftback? MrMondayNite Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 11-05-2006 01:39 PM
