Old 07-11-2011, 09:23 PM   #1
jerome
Toyota
Drives: '11 5dr/5spd yaris
pros and cons of hub spacers
pros:
aesthetics
cons?
i've heard of strain on wheel bearings... what about handling... any pluses there?
or are the cons so miniscule that it's negligible?
jerome is offline   Reply With Quote
Old 07-11-2011, 09:55 PM   #2
YarisSedan
Drives: 08 Yaris Sedan
Strain on the wheel bearing only occurs if you use hub spacers that go on the outside of the hub that require larger wheel studs. Those over time can cause above normal condition wear on the wheel bearings. Even then it could be years before you see any type of wheel bearing failure. The pengin hub spacers garm sells go behind the hub and between the knuckle. That wont cause any strain on the bearing. So if you get those there are no cons. What you can expect is wider rear tracking which in turn will give you greater stability and cornering as well as filling out the fenders better.
Only con i could think of is if you have wider tire/rim package where you dont rub this may occur using spacers.
Old 07-11-2011, 11:29 PM   #3
^ +1
The only con I can think of is that you have to take it apart to remove them. Pretty small con though!
Old 07-12-2011, 10:34 AM   #4
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
the greater stability is what im seeking as it seems my rear wants to slide out on me during high speed cornering with my 18's.....
ROCKLANDTOYOTA is offline   Reply With Quote
Old 07-12-2011, 01:03 PM   #5
^ front sway bar!
and yeah, the hub spacers should help some.
Old 07-12-2011, 03:19 PM   #6
ROCKLANDTOYOTA
JOE GIRTH
Drives: YARIS 3DOOR
^ front sway bar!
front sway bar from a yaris sedan or ????
Old 07-16-2011, 02:00 PM   #7
jerome
Toyota
thanks guys, appreciate the advice
Old 07-16-2011, 08:12 PM   #8
The 25mm front sway bar I sell.
http://shop.microimageonline.com/Ult...R-AR25-311.htm
Pros and cons of only upgrading to stiffer rear shocks? YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 02-04-2010 11:31 PM
Handling changes from rear hub spacers and minor concern. YarisSedan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 07-10-2009 08:07 PM
Different brands of speakers....pros and cons myt In Car Entertainment + Electronics (audio / video / alarm) 2 09-26-2007 02:50 PM
