#1 |
Immobilizer
Does anyone know on the 2007 hb(manual) were is the clutch wire that completes the starter circuit ???
iSRA |
The clutch switch is mounted to the arm of the clutch pedal and has a black and yellow wire. From there they go to connector A25, which is in the bottom of the under-hood fuse panel. From there the black wire is the positive for the START relay coil. The yellow goes back through the firewall to the keyswitch and splits into the two black ST2 wires in the keyswitch connector.
#3 |
thanx a lot. If i were to put a kill switch on that cable which one would u recommend i use
iSRA |
#4 |
I think I'd follow the two clutch switch wires to where they get ready to go through the firewall and cut and split one of them there.
#5 |
ok thanx a lot for ur help
iSRA |
| 2010 Yaris Sedan - Need Key Programmed to the Immobilizer | vst | General Yaris / Vitz Discussion | 0 | 04-17-2011 04:29 PM |
| Bypass Immobilizer? | Lil Abner | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 08-19-2010 09:11 PM |
| Best anti-theft strategies for Yaris without engine immobilizer? | rtom | General Yaris / Vitz Discussion | 34 | 01-06-2010 01:56 PM |
| Engine Immobilizer p/n | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 08-24-2009 11:11 PM |
| After-the-fact engine immobilizer? | Echostatic | In Car Entertainment + Electronics (audio / video / alarm) | 1 | 08-01-2007 10:03 AM |
