Old 07-26-2011, 04:24 PM   #1
T Pexx
Drives: 08' toyota yaris liftback
Question fuse help
sorry if i sound like a noob but where can i get a 7.5 amp fuse?
T Pexx is offline   Reply With Quote
Old 07-26-2011, 05:28 PM   #2
Revsson
NAPA, O'Reilly Auto parts, Fry's, etc.
Old 07-27-2011, 07:42 PM   #3
MadMax
MadMax's Avatar
Depending on what fuse you're replacing, such as the ones under the steering column; you may need a low-profile mini fuse like this one...
Notice it does not have the blades like a regular mini fuse!
A regular mini fuse will not allow you to put the door back on the fuse box!
Cheers! M2
Old 07-28-2011, 05:38 AM   #4
henry98
Drives: toyota
madmax is saying right its depending on the fuse.
Dent Removal Services
henry98 is offline   Reply With Quote
Old 07-28-2011, 02:26 PM   #5
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
Also, in case of emergency or you're in desperate need of a fuse (just to get by temporarily until you get to the auto parts for the the correct value), you could check the underhood fusebox for spares.
-toy
Old 11-01-2011, 02:30 AM   #6
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
Silly question, how do I get to the fuse box inside the cabin?
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 11-01-2011, 10:43 AM   #7
EPyarisdriver
...or Vegas for short
EPyarisdriver's Avatar
Drives: 2010 Toyota Yaris 3door LB
You have to get on the floor board where the pedals are and look up. You should see a white rectangle (this is the cover of the fuse box)
Just pull off the cover and there are your fuses
EPyarisdriver is offline   Reply With Quote
Blown Fuse - Stereo !?! click.mine In Car Entertainment + Electronics (audio / video / alarm) 16 10-05-2017 08:35 AM
Cigarette Lighter Fuse stellar DIY / Maintenance / Service 10 01-30-2010 03:08 PM
What does these fuse names mean? mudi General Yaris / Vitz Discussion 0 01-29-2010 12:13 PM
fuse box for fuse for brake lights drew999 General Yaris / Vitz Discussion 2 01-19-2010 02:38 PM
2009 empty, usable fuse location? schleppy In Car Entertainment + Electronics (audio / video / alarm) 3 04-23-2009 12:07 PM
