Old 07-27-2011, 06:07 PM   #1
RMcG
Drives: Yaris manufactured after 2007
Battery capacity with engine off
I am interested in running a fan in the car at night (with the engine off) while I sleep in the car. I have two fans. Fan #1 runs off 12 volts 0.8 Amps 10 watts. Fan #2 is AC (117 volts AC, 20 watts of less 50-60 Hertz) and runs off an AC-DC converter in the 12 volt DC power outlet.
QUESTION: How long can I run one of these fans without discharging the battery enough to keep the car from starting?
Thanks,
RMcG
RMcG is offline   Reply With Quote
Old 07-27-2011, 06:20 PM   #2
If the stock battery is rated for 45 Ah (Amp hours), then you can safely discharge it to 1/2 of that before damaging the cells. Unfortunately, at 22.5 Ah of charge, it may not have enough power to crank the starter, so I would limit myself to about 11 Ah of discharge before running the engine long enough to fully recharge the battery. With that said, that would mean that you could theoretically run your 0.8A one for 13.75 hours. The AC fan running off of the inverter will draw quite a bit more because of the inefficiency of the inverter.
Old 07-27-2011, 06:34 PM   #3
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Add a second battery, and or a battery switch...like on a boat.
-Type 07 FFL-
My odometer 03/11
Old 07-27-2011, 09:12 PM   #4
RMcG
Thanks Scott and Mazilla. RMcG
1ND-TV engine swap Daox Fuel Economy Forum 11 10-01-2015 02:49 PM
Battery drain by radio circuit dslc DIY / Maintenance / Service 2 08-02-2010 04:21 PM
Running battery cable from engine room jakobmagnusson In Car Entertainment + Electronics (audio / video / alarm) 5 07-24-2010 09:34 AM
The last gas question Tonavi DIY / Maintenance / Service 56 04-27-2009 08:40 PM
Yaris 06 H/B Engine Cutting out problem.. Farenheit General Yaris / Vitz Discussion 3 09-14-2007 01:21 PM
