Old 08-02-2010, 03:03 PM   #1
dslc
Drives: '99 Yaris
Battery drain by radio circuit
The circuit which includes the radio and cassette player in our old '99 Yaris is drawing almost 200 milli-amps when the engine is switched off.
Naturally, if the engine isn't run for a day or two, the battery can go flat - not good.
(From what I've read, a car - when all the electrics are switched off - shouldn't draw more than 50 - 75 mA from a battery?)
When I take out the relevant fuse - a 15 A - the drain on the battery drops to about 20 - 40 mA, if I recall correctly.
The down-side of taking out the fuse is that I can't have any music when I drive. But, perhaps more importantly, this circuit also powers the headlight beam indicator - so it would be good to get it fixed.
Has any one experienced this sort of problem before? I just wanted to make this enquiry, before trying to delve any deeper myself. The car is fairly old.
Is it likely that the radio is the culprit?
I need to double-check what else is on the circuit.
dslc is offline   Reply With Quote
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 02:12 PM
DIY: Braille Battery install texkid DIY / Maintenance / Service 39 02-19-2013 02:40 PM
ATL, I want to trade my Upgraded built in radio... matthewallanstill Southeast 2 03-28-2009 06:29 PM
Battery Current Drain karlb General Yaris / Vitz Discussion 3 12-09-2008 04:28 PM
