Old 08-16-2011, 09:44 AM   #1
ChinGy
Drives: Yaris T Sport
Exhaust Port Size
Hello
I'm new to the forum. First time posting. Long time reader. I have a UK 1NZ-FE Yaris T Sport. I'm looking to have a custom exhaust header (manifold as we call it in UK) made up with longer runners to hopefully gain more power out of the engine. I currently have an OBX header which has been running fine for years, but I just want more out of the car.
Does anyone know what the exhaust port size are? The fabricator is currently making the head flange and wants to know the measurements so that they could make the runner's diametre slightly bigger, and not too big.
ChinGy is offline   Reply With Quote
Old 08-16-2011, 09:46 AM   #2
Welcome to the forums.
That's the 1.8L right? Do you still have your stock header?
Old 08-16-2011, 10:49 AM   #3
ChinGy
It's a 1.5L, NCP13.
I do have the stock header. It looks about 1.25" (31mm).
The gasket bore size is about 41mm (just over 1.5")
Which is rather odd as that would mean the runners are smaller than the ports.
Shouldn't it be the other way around? With the exhaust ports being smaller than the runners.
Old 08-16-2011, 07:17 PM   #4
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Smaller runners reach peak velocity sooner building torque
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 08-16-2011, 08:57 PM   #5
ChinGy
Great fact. But it would be nice if the runners were slightly wider than the port to stop reversion.
If anyone has a cylinder head out. Could you please confirm the exhaust port size?
))) TS exhaust - what size , and what gains ((( aucorium Yaris TS Talk 4 03-22-2010 02:40 AM
Size of exhaust hanger?? AlainMikli Performance Modifications 3 07-05-2009 05:07 PM
does BACK-PRESSURE increase MPG vs straight thru... marcus Fuel Economy Forum 25 05-03-2009 09:23 PM
Exhaust Pipe Size (Tamaņo del tubo de escape) carlosh Central and South America 11 08-02-2007 04:15 PM
