Old 08-20-2011, 02:18 AM   #1
spdas
Drives: Yaris Electric
Small side windows as a vent
Aloha. I am looking to mount the side mirrors inside on the pillar between the large rollup and small window . I also would like to remove the small window and make it into a vent. Anyone done this or know where any aftermarket parts may be available? Purpose: The Yaris 2007 3dr HB is Electric and I am trying to streamline to get more miles per charge and also not use the A/C and keep the windows up. I get 100 miles per charge when driving at 65mph, but I Like to tinker and get MORE.
thanks
francis
spdas is offline   Reply With Quote
Old 08-20-2011, 06:39 AM   #2
Klink10
Klink10's Avatar
I have researched this and found no one as far as the vented side windows. I've been wanting to do mine much like the old VW bugs.
Old 08-22-2011, 06:02 PM   #3
Yaristeve
Drives: 3-door hatch
Similar question has been raised on the Miata.net forums and the closest you can get to a vent window in the little triangle is to replace the glass with plexiglas or lexan and then install one of these:
http://www.aircraftspruce.com/catalo...snapvents3.php
One of the advertising vendors on Miata.net actually makes (made?) a kit for the Miata but you'd be on your own for the Yaris...
Old 08-22-2011, 11:38 PM   #4
Use F1 style mirrors like I did. Then convert to a Wink mirror inside. You won't even need side mirrors with the Wink. Easy.
Mitsubishi small car concept previews new Colt - likely a return to America Kal-El Off-topic / Other Cars / Everything else Discussions 14 03-04-2011 05:50 AM
Anyone here trim off the sides of the weathertech vent visors? marlondog Cosmetic Modifications (Exterior/Interior) 9 02-11-2010 11:36 AM
Windows Misaligned Kaotic Lazagna DIY / Maintenance / Service 4 01-24-2010 02:02 AM
Are the optional airbags worth it ? avenno2g7 General Yaris / Vitz Discussion 46 12-07-2008 02:40 AM
Power Windows Leg Room nwdixieboy General Yaris / Vitz Discussion 9 04-06-2006 07:19 AM
