Old 08-24-2011, 02:28 PM   #1
josh044
Drives: 07 yaris hb - 5 spd
Sound Deadening - most effective?
What is the best bang for the buck as far as bringing the in-cabin sound level down. I guess I'd also consider best bang for time involved. I rather not remove the entire interior.
From my own ears it seems like a lot of noise comes from the wheel wells. Is coating the wheel wells (on the outside) the best bet?
Also, a lot of people seems to cover the wheel well with metal tape stuff. Is that area a prime culprit?
josh044 is offline   Reply With Quote
Old 08-24-2011, 07:14 PM   #2
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
In that case, I'd suggest ear plugs.
-Type 07 FFL-
My odometer 03/11
Old 08-25-2011, 11:47 AM   #3
josh044
Really? You think any incremental steps would be a waste of time? It seems like coating the wheel wells with a layer of truck bed rubber coating might put a good dent in the noise.
Old 08-25-2011, 01:24 PM   #4
mazilla
advocatus diaboli
mazilla's Avatar
I used the spray and aluminum tape method and noticed a difference, but I had to tear down the interior. Given the amount of reduction I got from that I can't imagine you having much luck only hitting the underside of the fender liners. There are a few threads around that go into great detail on the subject...
-Type 07 FFL-
My odometer 03/11
Old 08-25-2011, 01:35 PM   #5
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
I notice alot of wind noise at freeway speed. You can squeeze in foam caulk rope into your door seal to provide a even tighter seal to prevent wind noise.
Its this stuff: http://www.acehardware.com/product/i...Id=57906222043
Check out my Build thread:
Old 09-04-2011, 11:43 PM   #6
BLOODY_STONE
Drives: 2009 toyota yaris 1.3 sedan
I sprayed an undercoat rubber spray and it increased insulation by about 40% ..... Not bad ... Still didnt insulate the doors
BLOODY_STONE is offline   Reply With Quote
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-04-2011 11:56 PM
Yaris SR - JL Audio Install + Sound Deadening (Progress Thread) Nips In Car Entertainment + Electronics (audio / video / alarm) 8 03-18-2011 12:42 AM
cheap sound deadening p123456789 In Car Entertainment + Electronics (audio / video / alarm) 21 11-03-2010 05:06 PM
sound deadening material??? are names worth it? severous01 In Car Entertainment + Electronics (audio / video / alarm) 15 08-07-2010 09:06 PM
Sound deadening questions cast DIY / Maintenance / Service 7 03-16-2010 12:46 PM
