Old 09-03-2011, 10:10 PM   #1
Hershey
Instrument Cluster panel : daytime lighting ...
doesn't work , can see it get somewhat brighter and then dim over and over . The lighting is fine when any of the lights are on . Can adjust the brightness as well . So , what can be the culprit ? Last , the rolling control knob is not turned up all the way when it clicks . This is the '08 sedan and is not equipped with daytime running lights . Thanks .
Old 09-03-2011, 10:36 PM   #2
Hershey
Or does it light up during the day ? I forget , the other 1/2 drives it more than I do .
Old 09-04-2011, 09:54 AM   #3
SKurj
Drives: 09 Yaris 3dr HB, BRZ
The dash lighting on the yaris leaves something to be desired. The only time I find them bright enough is when they are turned all the way up and the knob clicks. The range you can select prior to the click just isn't bright enough IMO.
(errm thats on my 09 lb)
SKurj is offline   Reply With Quote
Old 09-05-2011, 11:33 AM   #4
Hershey
Think it may be the light control rheostat switch . These aren't cheap . Hopefully it's covered by the Platinum extended warranty .
Old 09-11-2011, 05:11 PM   #5
i'm not sure about the 08, but my 07... you shouldn't turn the knob until it clicks. When you turn on the lights, the whole cluster stays dark, except the little digital display, if you "click" it...
Old 09-12-2011, 03:22 PM   #6
DebbyM46227
DebbyM46227's Avatar
Drives: 2017 Yaris IA, Pulse Red, Auto
The only time I have a hard time seeing my cluster is when I have my headlights on during the day (for instance, driving in the rain). The rest of the time they are bright enough and I only have mine turned halfway towards the click.
DebbyM46227 is offline   Reply With Quote
07' Instrument Panel in 11'? jeeper5usa Cosmetic Modifications (Exterior/Interior) 6 03-17-2011 02:50 AM
what is behind the instrument panel henry33 DIY / Maintenance / Service 3 12-10-2010 09:16 PM
Question about replacing Instrument Panel!! Wowzers78 General Yaris / Vitz Discussion 0 03-18-2010 09:25 AM
Sedan Instrument Cluster to LB Instrument Cluster Malaya1221 Cosmetic Modifications (Exterior/Interior) 2 12-02-2008 10:05 PM
