#1 |
![]() Drives: 2007 Red Sedan Join Date: Aug 2011
Cup holder busted
I have a 2007 Sedan.
The driver side cup holder received an impact from a heavy object, and now the fluid opening mechanism is nonfunctional. I can't seem to find a way to take it apart to assess the damage. Has anyone taken apart a Yaris cup holder, or had similar symptoms? |
![]() ![]() ![]() Drives: 09 Meteoric Metallic 3 door HB Join Date: Jul 2010
Can you take any pictures of it?
#3 |
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
This might work till you find a fix.
Making a decision without following it with an action is still a fantasy. |
#4 |
![]() ![]() ![]() ![]() Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
Did you look at the pdf for the Instrument Panel?
Check out page 42, which shows how to take out the cup holder. http://www.etimago.com/yaris/repairm...nt%20Panel.pdf Otherwise, from page 40, it appears that you would have to take out the whole Instrument Panel, and remove 3 screws from behind? ![]() Let us know how you solve this issue. |
#5 |
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
I hate those cup holders, they usually spill fluid over your knee or soak anything you have in the small compartment under the cup holder and then with the mechanical operation it sooner or later fails,like my passenger side drink holder, refuses to lock in the closed position
probably a piece of plastic worn out.I wish they had just put a recessed cup holder without the door mechanism,would have lasted the life of the car with never a problem..
Have Yaris will travel.. |
#6 |
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
Squeeze the sides together to disengage the hinge pins. Watch for the small spring to eject.
Honestly, I don't recall anything as sexy as a "fluid opening mechanism" being included in the re-assembly after mine popped apart once due to a side impact.
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
| Tags |
| cabin, cup holder, interior |
| CUP HOLDER REMOVAL? | SweetRS | Cosmetic Modifications (Exterior/Interior) | 13 | 09-19-2016 08:43 AM |
| Dash Cup Holder | dzcab | Cosmetic Modifications (Exterior/Interior) | 5 | 08-17-2011 10:24 PM |
| cup holder removal | DOMAV | General Yaris / Vitz Discussion | 9 | 08-27-2009 11:32 AM |
| Install Oil Pressure, Voltage and Temperature Gauges with DIY Holder | bieniman | DIY / Maintenance / Service | 4 | 05-19-2009 11:40 PM |
| A eye for a eye but a Ipod for a cup holder? | yrsdrgn | DIY / Maintenance / Service | 30 | 05-08-2007 02:51 AM |
