Old 09-18-2011, 07:50 AM   #1
SUB7
Drives: Toyota Runx
Radio sometimes doesn't turn on.
Hi guys.
When ever i start the car the radio would immediately turn on but the few odd occasions, it just wouldn't. I also try to turn it on via the power button and theres no power.
My only way around this is to shut off the car and start it once more. Then every thing will continue to work as normal.
What can possibly be the cause of this?
A fuse need replacing?
SUB7 is offline   Reply With Quote
Old 09-19-2011, 10:55 AM   #2
Lil Abner
Drives: 2009 3dr LB Manual
Did you do the install? Did a buddy do it? Sounds like a loose connection. I'd say pull the radio out and check the power and ignition wires (red and orange/yellow) and make sure they are solid/secure. Give them a pull and see if they come loose from the connection. If the wires are just twisted and taped, get some butt splice terminals. If there are Blue Scotch locks on the factory wires, they should be Red.
Old 09-20-2011, 09:48 PM   #3
SUB7
Drives: Toyota Runx
its the factory system.
I'll have someone look at it for me, thanks for your reply.
I really thought i needed to replace a fuse or something.
I had a engine management system install around that time i believe.
Old 09-20-2011, 09:53 PM   #4
YarisSedan
Drives: 08 Yaris Sedan
Thats actually happend to my car a few times. I ended up putting in a aftermarket setup and havent had any issues since.
Old 01-01-2013, 11:46 AM   #5
Martinezn.964
Drives: 07 Sedan S
You can push the rear defrost button and radio will turn on.
Martinezn.964 is offline   Reply With Quote
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 02:12 PM
Will local bay area members please stand up! YarisSedan California 264 07-28-2009 11:53 PM
ATL, I want to trade my Upgraded built in radio... matthewallanstill Southeast 2 03-28-2009 06:29 PM
Mounting a CB radio somewhere Sodium Duck Cosmetic Modifications (Exterior/Interior) 1 03-06-2009 01:50 AM
I want to trade my Upgraded built in radio... matthewallanstill Items for Sale by private party 0 09-03-2007 09:50 AM
