Old 09-22-2011, 10:22 PM   #1
TwoBearWisconsin
TwoBearWisconsin's Avatar
Drives: 2010 Yaris LB/5, 1996 Miata
Buzzing rattle in door pillar
I have developed an annoying buzzing/rattling sound in my Yaris 5 door. It sounds like it is coming from the door pillar or the area where the seat belt comes out. Kind of like a metal wire is rubbing on something. It's not constant - I hear it some days and not others. When it's buzzing I even hear it when I close the driver's side door after getting out of the car.
Any one have any ideas what could be causing this, and how to get rid of it?
Thanks!
TwoBearWisconsin is offline   Reply With Quote
Old 09-22-2011, 10:57 PM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
You could take part the b pillar and take a look.. maybe somethign has just come loose
Old 09-25-2011, 07:51 AM   #3
traveller
Drives: Anything but Toyota
I have had similar in a Yaris hatchback and it appeared to be the seatbelt height adjuster. It was intermittent. Initially I thought it was the grab handle above the driver's door.
You need to be 100% sure it's coming from where you think though. Noises can be very deceptive in a car. In this instance I sold it on to someone else to find.
In a previous car I had a rattle which again seemed to come from the belt height adjuster, I was convinced, even going as far as removing "B" pillar trim to check. How wrong I was, it was coming from behind the rear door inner trim panel! A rear seat passenger pinpointed it for me.
As advised you might need to remove some trim to find it.
traveller is offline   Reply With Quote
Please help with Rattle coming from cam cover? c-dub DIY / Maintenance / Service 11 08-07-2011 09:33 PM
2010 US 5 door stock exhaust, big rattle 127.0.0.1 DIY / Maintenance / Service 3 06-20-2010 09:39 AM
rattle bluebeast General Yaris / Vitz Discussion 1 04-12-2010 01:13 PM
Source of buzzing sound.. CB900F2 DIY / Maintenance / Service 1 05-20-2009 10:19 PM
Rattle fixed! Bretsuaz DIY / Maintenance / Service 32 03-30-2007 08:39 PM
