Old 09-23-2011, 11:40 AM   #1
Connoisseur_of_fine_cars
Oh what a feeling
Connoisseur_of_fine_cars's Avatar
Tercel 13" OEM wheel
I saw a set of four 13" OEM steel wheel with good tires on a Tercel at the junkyard for $100. The bolt pattern and offset appears to be the same as the Yaris'. Will the 13" clear the front caliper? I'm tempted to put these on my Yaris just for fun and hypermiling.
Connoisseur_of_fine_cars is offline   Reply With Quote
Old 09-23-2011, 12:53 PM   #2
13's likely won't clear the caliper
Old 09-23-2011, 01:08 PM   #3
Oh what a feeling
I found discussions by UK yaris owner about 13" wheels. Apparently, 13" comes stock on some UK yaris. So 13" wheels do clear the caliper!!! Unless UK calipers are smaller than US ones.
http://www.carkb.com/Uwe/Forum.aspx/...ris-wheel-size
http://www.toyotaownersclub.com/foru...owtopic=119526
Old 09-23-2011, 06:53 PM   #4
Yarice
Yarice's Avatar
Drives: 2008 LB Meteoric Metallic
It depends on the 13", there's a member here with a white yaris running 13x7.5 +25 Lenso VPD.
Yarice is offline   Reply With Quote
Old 09-23-2011, 07:31 PM   #5
Oh what a feeling
I'm referring to tiny OEM 13"x4.5" wheel. It's only 4.5" wide.
Old 09-23-2011, 10:00 PM   #6
My bet is that they will. I tried 12" Subaru Justy wheels, and they were about 1/2" too small to clear the caliper. The opening of the back side of the rim needs to be just over 12" in diameter to clear the stock caliper and dust shield.
Old 09-23-2011, 11:06 PM   #7
13x8 V2
13x9 Compomotive
13" Weld drag wheels
I own all of these, all of them clear the caliper.
Old 09-24-2011, 12:53 AM   #8
could always stick some spacers on them too! :D
Old 09-24-2011, 08:30 AM   #9
13x8 V2
13x9 Compomotive
sorry, 13" steel wheels arent likely to fit around the caliper
its not the diameter that is like the issue, it will be the face of the wheel rubbing the caliper - - - which is to say the wheel isnt wide enough
Old 09-24-2011, 08:44 AM   #10
djct_watt
Drives: 2010 NCP91 5spd
Minimizing rotational intertia FTMFW! Thank you for not wanting to put "dubs" on the Yaris.
The best modification you can make is between the steering wheel and driver's seat.
djct_watt is offline   Reply With Quote
Old 09-24-2011, 12:58 PM   #11
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
+1
been there tried that
off my 92 tercel w/ the 13" steelies
OTA'sTOY is offline   Reply With Quote
OEM Toyota filters & Toyota wheel locks for sale mehullica Items for Sale by private party 7 12-11-2010 08:38 AM
OEM Steering wheel with cruise control? suckerface Cosmetic Modifications (Exterior/Interior) 9 07-25-2010 08:40 PM
Looking for OEM wheel covers grunke Items for Sale by private party 5 12-09-2009 10:11 AM
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
