Old 10-07-2011, 03:32 PM   #1
w7ist
Drives: 08 yaris lb
Wanna go lower than my coilovers allow :/
I am fairly new to the yaris in general. I am coming from the miata world where my cars lowest point was about half an inch off the ground, so I don't need to be told how impractical having a super low car is, or the dangers of exposing parts to damage or prematurely worn out shocks. I am going into this fully aware.
That being said!... I recently purchased some tein basics and installed them. They are all the way down all around but I am quite a bit disappointed with the drop... I know for the rears I could probably just remove the collar set up all together (it'd basically just be a tein lowering spring with the tein shock. But for the fronts, removing a collar isn't going to give me much more of a drop.
Is there anything similar to a recessed top hat that can be purchased for the fronts so I can get that extra bit? Can anyone recommend a way to go about this? The suspension set up on the Yaris seems... odd... to say the least coming from dual wishbone all around on the miata. I'm not sure how to approach this.
Any help is appreciated! Thanks!
w7ist is offline   Reply With Quote
Old 10-07-2011, 03:55 PM   #2
SAV912
Pirate Yaaaaris
SAV912's Avatar
Coils aren't the way to get all the way down to 1/2" on the Yaris. Especially Tein Basics. Those are some of the softest coils on the market for our cars.
The suspension setup on the Yaris is pretty basic. As far as I know, even Megan, D2 or Tein SCs are not going to get you 1/2" from the ground, cranked all the way down with the collars removed. The car sits so high stock that you just aren't gonna get that low without cutting a serious chunk out of lowering springs or just biting the cost and going to bags.
If you're trying to go the 'stanced' route, there are several VW forums for that.
All that said, if you decide to ditch the Basics, let me know. I'll put 'em to some good use.
-C
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
Old 10-07-2011, 08:01 PM   #3
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
hmm.. I am curious.. I have megan coil overs and i am curious how low it will go.. i may try that this weekend..
-Derrick-
Old 10-07-2011, 08:11 PM   #4
jekqmb
Local Sh*t Disturber
Drives: 2009 Yaris LB
Hmmm I have Basics and my car is one of the lowest on the site..... :)
But I work at a performance shop that specializes in SCCA cars so our head mechanic did some work to them, im at about 3.2" front and rear drop wise on Tein Basics! I still can go almost 1 more whole inch on mine. Megans you can set your frame almost on the ground but you cant drive it that way.
Old 10-07-2011, 09:06 PM   #5
CAyaris
CAyaris's Avatar
Send a message via MSN to CAyaris
im on kido coilovers and i sit 3 inches from the front bumper to ground
108hp and still rolling
CAyaris is offline   Reply With Quote
Old 10-07-2011, 09:10 PM   #6
jekqmb
^^^ what he said, whoever thinks you cant slam these cars is nuts!
A lot of us are doing it now even though its neck breaking haha
Old 10-07-2011, 09:23 PM   #7
MUSKOKA800
MUSKOKA800's Avatar
You guys obviously don't have the crappy highways we must tolerate. Our frost heaves exceed 3.5 inches.
Old 10-08-2011, 03:29 AM   #8
ilikerice
ilikerice's Avatar
hmm.. thanks for that heads up before I do that.. haha.. get it so low as soon as i get in it, it bottoms out
-Derrick-
Old 10-08-2011, 05:57 AM   #9
Look up Saggio's ride, he's about as slammed as can be on coilovers, maybe get some inspiration from that :)
Old 10-08-2011, 05:57 AM   #10
w7ist
Drives: 08 yaris lb
Don't get me wrong, all, I'm not trying to get to the same height as I was with the miata, I just can't stand how high it sits while it's still bottomed out. And I'm not trying to knock on you guys but three inches off the ground isn't "slammed" at least in my opinion. That's more than enough room for dodging most obstacles. It's just how you go about it that describes the practicality of the matter. :D
Anyhow... I did know that the teins were soft going into this, but I also was hoping for a bit more drop like the basics in the miata world. Mistake on my end, I know.
How feasible would it be to cut and reweld (by a professional fabricator that I know) the knuckle mounts on the front shocks a bit higher up? That would allow me to maintain travel and essentially just lower the chassis point, right? Am I all wet with this?
O, just a few numbers for reference. With these all wound down I am at 12.25 fender to center hub in the front and 12 fender to center hub in the rear. The OEM bumper is 6 inches off the ground still! -_____-;;
Old 10-08-2011, 06:13 AM   #11
ilikerice
ilikerice's Avatar
totally agree on the hieght of this car.. it just seems soooooo tall.. After looking at Jason's H production car running against crx's and civic hatch's, Yaris looks like a bubble compared to those in a race.. just looks wierd.. but it was impressive how fast it was.
Its the shape of the body thats making this car look tall to me.. the roof is made for alot of head room for every shape and size of passengers. What size rims and tires are you using?
I cant say for sure about the knuckle mounts relocation. Not that familiar yet
-Derrick-
Old 10-08-2011, 06:17 AM   #12
w7ist
Drives: 08 yaris lb
Rims are the OEM steelies and it has 195/55/15s. Soon to have Rota Zeros (I know, I know) in 15 with 205/50/15 azenis.
Old 10-08-2011, 03:21 PM   #13
jekqmb
Relocating the Knuckles mounts can be done :)
Old 10-08-2011, 04:12 PM   #14
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
REally you want to drive I5 and I405 slammed daily...........most functional way to get low with it is bags....got a guy in Burien who is a retailer for them and will get you a good deal.
Old 10-08-2011, 05:58 PM   #15
lol
Old 10-08-2011, 11:20 PM   #16
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
Lol I am completely slammed all the way on Megan and had 15" wheels and scratched the bottom of my car on every bump on streets and speed bumps my car would get stuck lol
Originally Posted by sw07gt
Old 10-09-2011, 03:07 AM   #17
w7ist
Drives: 08 yaris lb
Believe me, I table topped my miata more than once where the chassis was on the ground and I had to rock the car back and forth to put the rear wheels on the ground and get traction.
Old 10-09-2011, 03:17 AM   #18
w7ist
Drives: 08 yaris lb
lol
Now, now.. Why is this funny? I have them already in my closet they are just waiting for rubber. >_> <_<
new pics... ait diablo kit+ cusco coilovers blacksandiegovitz Photo-Video-Media Gallery 49 05-16-2011 06:50 AM
who got megan coilovers walt101786 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 04-04-2011 07:55 PM
FT: Tein basic Coilovers SOCAL!!! Mister Z Items for Sale by private party 0 03-27-2011 05:24 PM
FS: BC Racing Coilovers BR Series Non-Inverted FunctionSpec Items for Sale by private party 9 06-02-2010 01:34 PM
Should I lower the PSI during the Winter? paulyd0021 General Yaris / Vitz Discussion 5 12-10-2009 06:49 PM
