Old 10-20-2011, 10:25 PM   #1
m_gtz
Drives: 2009 Toyota Yaris Sedan
Fog Light Help
Hello to all,
I received the fog lights today, and it is a little more difficult than I thought. I'm still in the planning stage, but can someone tell me if I'm on the right track?
Fog light red wire goes to power source in engine compartment fuse box.
Relay: blue/yellow wire not used. Where does red wire go? Inside fusebox?
Switch needs to be modified: blue wire gets cut from relay and goes from switch to D4. Green wire from switch also goes to D4 and other green wire gets tapped to power source.
Except for the questions, am I on the right track? Thanks in advance.
Mike
m_gtz is offline   Reply With Quote
Part #s for Fog Light install? Can anyone who works for Toyota confirm? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 73 12-23-2010 05:15 PM
test fit 06-07 Yaris 4 door fog light winson California 15 01-13-2009 08:25 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
