Old 11-09-2011, 09:02 PM   #1
cron
Drives: Yaris LE 2011 / RAV4 4WD 2011
Remote key entry?
Hi all, we just bought a Yaris hatchback 2011. It has power locks (no power windows), but it doesn't have the remote to lock/unlock.
Is there a way to install some module that would give us remote locking/unlocking? If so, any DIY and/or suggestion for parts?
Thanks!
cron is offline   Reply With Quote
Old 11-10-2011, 11:10 PM   #2
cron
I hate to reply to myself, but more digging provided the search terms I needed (I think). "remote keyless entry" is probably what I'm looking for.
I found a tutorial on this forum about installing a "valet 712" system. On the other hand, I read a few things like this. The latter seems to suggest all I need is to buy a remote and program it with the car. Is that so simple? No box to add like it's described for the "valet" system? I don't need an alarm or remote starter.
I just want the already powered locks to be controlled from a remote. Can someone enlighten me? Thanks!
Old 11-11-2011, 06:54 AM   #3
Adding an aftermarket system will be cheaper, but you could also convert it to OEM keyless entry via the purchase of the Door Control Receiver and a key with the transmitter fob.
My 09 came the same way, and I added a keyless entry with remote starter. In the DIY section of the forum there's a sticky for my DIY for keyless entry with remote start.
Old 11-11-2011, 11:26 PM   #4
cron
I'll do some research. I didn't find your DIY (only DanQ's, which I was referring to in my second post).
I don't need the starter, so I thought it would be easier to find a DIY for just the remote keyless entry. Of course, OEM with original keys would be awesome, but I'm not sure where to get the parts.
Anyway, as it's already well-documented, I might go with the Valet 712T solution.
Transponder key programming teddy DIY / Maintenance / Service 6 04-28-2015 06:32 PM
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
Yaris 2007 remote entry doesn't open (it only closes) nicorac In Car Entertainment + Electronics (audio / video / alarm) 7 09-08-2011 11:02 AM
Need remote key fraenx DIY / Maintenance / Service 1 06-26-2009 07:29 PM
Should I add remote key less entry? Options YotaYarisUSA General Yaris / Vitz Discussion 13 05-02-2006 05:06 PM
