#1 |
![]() ![]() ![]() Drives: 2012 Yaris 3-door w/5-speed! Join Date: Nov 2011
A question about wheel weight...
I am getting a '12 Yaris in a couple of months with pressed steelies (L 3-door hatch), and I just want confirmation from anyone who might know:
http://www.toyota-parts.com/scripts/...idproduct=-312 Do these machined aluminum wheels weigh more than the stock steelies? If so, by how much? Does anyone have some solid numbers on these wheels? Thanks. |
Does no one know the weight of these wheels? I really am surprised!
#3 |
I have no concrete answer for you but since steelies weigh approx 1 lb/inch + 1 lb, I'm guessing those alloys will be up to 2 lbs heavier.
#4 |
Drives: yaris Join Date: Jan 2011
guess ?
they are the same or slightly heavier. standard mom+pop sedan OEM alloys are usually the chunkiest and strongest of all alloy wheels...hence a tad heavy. for less dollars (100 each) you can get a lighter aftermarket 15 inch alloy somewhere |
#5 | ||
I just like this set because they aren't overly "blingly", giant heavy wheels that will hurt my MPG for looks. For me, polished aluminum > chrome-plated anything any day. Again, thank you both. I think the trade-off is worth the slightly higher weight. Plus, the price is sweet enough for me to justify. |
#6 |
these are under 100 bucks each and are about as non-flashy as you can get, they look so much like an OEM
http://www.tirerack.com/wheels/Wheel...Silver+Painted I use them as winter wheels http://www.yarisworld.com/forums/showthread.php?t=37010 these here are ten spokes and on sale for 84 bucks http://www.tirerack.com/wheels/Wheel...All&sort=Brand |
#7 | |
#8 |
Um, all those wheels I showed you have a 4x100 lug version
![]() in fact this is how most wheels are photographed on wheel buying web sites, the 5 lug money-shot. When you actually put in your vehicle data then you find out if they have a 4x100 version of a rim in a particular size and width They only took a picture of the 5 lug. |
#9 |
![]() ![]() ![]() Drives: 09 Meteoric Metallic 3 door HB Join Date: Jul 2010
These are the wheels I have: http://farm7.static.flickr.com/6177/...fb82c0a292.jpg
They are SSR Type F's in silver, and mine are 16 inches, they weigh 11lbs each which is lighter then the 15inch OEM steelies. Mine are also the 10 spoke version, I believe the ones in the picture are 12. Edit: And yes, mine also are the correct bolt pattern. |
#10 |
$10.25/hr frying chicken
I almost bought theses wheels. I called him up and they are OEM
http://www.ebay.com/itm/SET-4-ALLOY-...item336dca48b2 |
#11 | |
#12 | ||
| Official YARIS Wheel & Tire Guide | Black Yaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 404 | 06-02-2026 01:19 PM |
| new wheel? | Nekofelin | DIY / Maintenance / Service | 1 | 08-10-2010 02:37 PM |
| Steering Wheel Issue. | Twistoffate0817 | General Yaris / Vitz Discussion | 8 | 01-31-2009 07:38 PM |
| weight on rs 15 inch wheel. | marcus | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 05-04-2007 11:20 AM |
| Wheel Care Question - Polish coming off? | Ran Kizama | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 0 | 04-25-2007 05:49 PM |
