Old 12-01-2011, 03:45 PM   #1
mr_miles
Drives: 2013 Yaris
rear fender separated!
was doing the speaker install in my gnarish (HB) today, looked in at the fender and saw light. thought it was a little odd, possibly a reflection, so i stuck my head in further, turns out my outer fender has separated from the inner! i don't have a welder to spot weld it back on, but its only about about 1/4 inch apart. I was thinking, would automotive urethane be good enough? it holds glass in, figured it would hold that together, too. Mostly concerned about keeping the inside dry, is all.
Old 12-01-2011, 04:08 PM   #2
I just checked on Crashy, and on her more banged up side hers has a gap. It appears that it wasn't welded, but rather just had the panel adhesive holding that seam together.
Old 12-01-2011, 04:20 PM   #3
mr_miles
Drives: 2013 Yaris
should be yellow, correct? I noticed that in there as well, and figured that it was used as sealant / glue along with tack's. kind of makes me feel better knowing that they aren't actually tacked. guess I'll go get some glue!
Old 12-01-2011, 04:56 PM   #4
I think it actually starts off greyish, but discolors to yellow. It looks like the same material that is used on the seams under the carpet.
Old 12-01-2011, 11:06 PM   #5
mr_miles
Drives: 2013 Yaris
ah, cool. I'll be picking some of that up asap. OCD is kicking in, gotta fix it.
2012 Nissan Versa Kal-El Off-topic / Other Cars / Everything else Discussions 22 06-15-2012 04:48 PM
Any decent looking rear fender skirts? Flipper_1938 Fuel Economy Forum 0 03-14-2011 11:54 AM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
