Old 12-08-2011, 09:41 AM   #1
Kendrik
Drives: 2011 Yaris Sedan
Steering Feels loose
went back to stock wheels/springs and now the steering feel seems loose. had it aligned but it's still there... the steering wheel goes from left to right on uneven roads but the car does not veer left/right. any insights on what to check / replace?
Kendrik is offline   Reply With Quote
Old 12-08-2011, 10:01 AM   #2
Captain Slow
My Face Is Ridiculous
Captain Slow's Avatar
Drives: 2010 Toyota Yaris 3dr LB
how many miles on the car?
Captain Slow is offline   Reply With Quote
Old 12-08-2011, 11:47 AM   #3
enviri
enviri's Avatar
Drives: 2010 Yaris
I have the same feeliing but my car is full of suspension mods and alot of chassis stiffening...thought it was normal lol.
Old 12-08-2011, 11:47 AM   #4
Kendrik
80,000 +
tire pressures are ok but I haven't had the chance to check the tie rods, steering columns, etc...
Old 12-08-2011, 12:10 PM   #5
Captain Slow
hmm...my car has almost razor-sharp steering.
this may be a total shot in the dark, since I have yet to really take a close look at the steering system of the Yaris, but if it has a "guibo" maybe it's worn?
it's basically a part that goes between the shaft of the steering wheel and the shaft that connects to the steering rack (at least on BMWs).
again, it's a shot in the dark. maybe pop the hood and see if you see any kind of bushings, etc... in the steering linkage.
Old 12-08-2011, 12:17 PM   #6
How much of a drop did you have with other springs? Did you have an alignment done after installing the aftermarket springs? If not, you may just be getting used to how the car feels with the alignment now at factory spec. Lowering springs change the alignment dynamics. You've probably also reverted back to skinner tires which can make the steering wheel feel looser as well.
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
Steering Wheel Issue. Twistoffate0817 General Yaris / Vitz Discussion 8 01-31-2009 07:38 PM
Loose Steering opus26 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 12-11-2008 11:27 AM
