Old 12-13-2011, 10:24 AM   #1
jeff69dini
Drives: 2007 Yaris Sedan 4 Door
little black arm/hinge on door??
ok, funny question, does anyone know what the official name of that part is? its the little black plastic arm on the back doors that functions like a sliding hinge, guess prevents door from opening all the way or something
strange thing is that yesterday I tried to open one of the back doors and it just stopped half way, it was greased and stuff, now it seems like its grinding on something opening and closing, how does this thing work? it slides inside the door, is it a simple thing or does it have bearings? etc
thanks
jeff69dini is offline   Reply With Quote
Old 12-13-2011, 10:43 AM   #2
A-Dingo-Ate-My-Baby
Drives: yaris
door stop check
they are pretty simple
http://www.ebay.com/sch/i.html?_from...All-Categories
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 12-13-2011, 10:55 AM   #3
jeff69dini
Originally Posted by A-Dingo-Ate-My-Baby View Post
door stop check
thanks!!! hmm, any idea why one might suddenly jam while the door was partially open? I sorta put more force on it and it opened all the way
Old 12-19-2011, 01:05 PM   #4
bobolinko
Bob
bobolinko's Avatar
Drives: Yaris and Scion XD 5 spd BSP
Before you spend any $ on it, try this:
Open the door all the way open. Might have to again use little pressure to open it all the way. Put some light oil (wd40) or the like on the bar portion of the stop check mech. Be sure to do the upper AND lower part of it. Close the door and open all the way repeatedly and most likely the movement will become easier. It sometimes gets "tight" when the mechanism does not travel over a spot often enough. (partially opening the dor all the time, vs opening the door all the way). I'll bet you "fix" the problem without lifitng a tool!
Good Luck!
bobolinko is offline   Reply With Quote
Door Handle LED DIY with pics window_lee DIY / Maintenance / Service 93 05-31-2012 11:58 PM
California May Ban Black Cars MadMax California 69 12-09-2009 10:44 PM
Black Door Armrests and A-piller Villen Cosmetic Modifications (Exterior/Interior) 1 07-20-2009 03:00 AM
Where can I get door edge protector? black rubber** Blenjar Cosmetic Modifications (Exterior/Interior) 5 03-13-2007 01:29 PM
Possible 4 door Yaris stateside? ElViShGiBbErIsH General Yaris / Vitz Discussion 19 05-18-2006 06:03 PM
