Old 12-13-2011, 12:40 PM   #1
intake
intake's Avatar
Drives: yaris 2 1.3 mmt
PULSARPLUGS
http://www.pulstar.com/main/PULSTAR-page.asp?P=40
anyone tested?
Yaris 2007 mmt 1.3 , denso power iridium, pipercross air filter, purplepower 10/40 motor oil + zx1, simoni racing silencer, eibach , henry hausen wheels, modified air box, trd logo,oversized oil filter.
intake is offline   Reply With Quote
Old 12-13-2011, 01:18 PM   #2
A-Dingo-Ate-My-Baby
Drives: yaris
The PulstarŪ megawatt of ignition power will improve all aspects of combustion quality in your engine. You will notice improved throttle responsiveness, more torque and better fuel economy. The amount of performance will depend on the make, model and condition of your engine. In general, you should expect torque to increase by 4 to 12% and realize a significant improvement in fuel economy. Watch the videos below to learn more.
Buy Now...
I also have fools gold for half the price of real gold, any takers ?
tl;dr
They will fire the engine, but you will not find any benefit over stock plugs. In fact
you are more likely to see worse performance.
A-Dingo-Ate-My-Baby is offline   Reply With Quote
Old 12-13-2011, 02:59 PM   #3
wildcard
wildcard's Avatar
Drives: 09 3dr HB 5sp
I use diesel spark plugs myself.
wildcard is offline   Reply With Quote
Old 12-13-2011, 04:49 PM   #4
ttr125fan09
ttr125fan09's Avatar
Drives: yaris
diesels have glow plugs, not spark plugs..
ttr125fan09 is offline   Reply With Quote
Old 12-13-2011, 06:44 PM   #5
I took my plugs out to save weight.
Old 12-13-2011, 07:40 PM   #6
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I just keep the pilot light next to the Bunsen burner lit...
Old 12-13-2011, 08:14 PM   #7
wildcard
wildcard's Avatar
sure they do. I'll take some pics when I install my cross-drilled brake lines.
Old 12-13-2011, 11:21 PM   #8
xixarchangelxix
The Unicorn
xixarchangelxix's Avatar
Drives: 2006 Yaris 5D HB
I use Bic Lighters instead of spark plugs. Gives me a 1.21 jiggawatt boost in hp. It's a good idea to change the flux capacitor fluid once every seatbelt rotation for the best performance.
xixarchangelxix is offline   Reply With Quote
Old 12-13-2011, 11:29 PM   #9
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
If you are using Bic Lights, watch out that you don't get any fluid into your blinker fluid reservoir. I hear that that is the number one cause of folks not using their signals in traffic.
Old 12-14-2011, 12:13 PM   #10
Jedz123
Two Wheeled Fiend
Drives: 08 Yaris 2D Lftback 5-speed
LMAO this thread is ridiculous...
2008 Suzuki B-King
2001 Yamaha FZ1 (2005 motor swap)
1998 Suzuki Bandit 1200S
1983 Suzuki GR650
2008 Toyota Yaris 2DR HB (The Cage)
Jedz123 is offline   Reply With Quote
Old 01-09-2012, 10:34 PM   #11
hotlavaxB
Drives: 2004 scion xb
hey intake..i used them in my box and did notice better fuel economy and a little boost in hp...however...the plugs only last 40k miles..even says so on the package..not a good value with what they are asking per plug. NGK Iridiums are the way to go..they last atleast 100k or longer. sorry you didnt get a straight answer from anyone..but now you got one from me!! hope this helps.
hotlavaxB is offline   Reply With Quote
Old 01-10-2012, 11:28 AM   #12
A-Dingo-Ate-My-Baby
Drives: yaris
my other 2 cents
if you see any benefit from installing these, you would have seen
the same exact benefit from installing any other compatible new plug
the new plug effect can make you think these are 'magic' when in fact
your previous plugs were just a bit worn or dirty
