Old 12-14-2011, 08:39 PM   #1
bronsin
bronsin's Avatar
Which Fuse To Pull...
I want to disconnect the AC for winter use. But which fuse does one pull? There are like 3 in the engine compartment box and a 7.5 amp in the big panel in the interior.
Just where is that big interior panel? Under the dash?
Thanks!
Old 12-14-2011, 10:29 PM   #2
If you pull the 7.5A one in the under the bottom of the dash panel, you will kill the AC ECU, but that will also prevent the rear window defogger and PTC heater from working.
The fuses under the hood are for the blower motor and the PTC heater.
So, to kill the AC for the winter and still have everything else work you would either have pull the connector from the compressor (and somehow seal both ends from the weather) or disconnect the green wire in pin 7 of the 16 pin connector on the AC ECU. That pin is the output to the AC compressor clutch.
Old 12-15-2011, 06:12 AM   #3
bronsin
bronsin's Avatar
Ah thanks. I was all set to go willy nilly pulling fuses but thought I should find out what everything did first.
So the mod to disconnect the defroast from the ac is really the best bet if you want everything to function.
Old 12-15-2011, 07:50 AM   #4
Correct
Old 12-15-2011, 08:17 AM   #5
Yaris Blue
Drives: 2010 Blue Yaris LB
I have pulled the 7.5A fuse under the dash and my rear window defogger still works. But the button for the rear window defogger doesn't light up when the defogger is turned on.
Yaris Blue is offline   Reply With Quote
Old 12-15-2011, 08:54 AM   #6
bronsin
bronsin's Avatar
Huh the manual just says AC for all three under the hood.
Which couldnt be true!
Old 12-15-2011, 09:15 AM   #7
bronsin
bronsin's Avatar
Awesome! Thanks for that.
Old 12-15-2011, 09:17 AM   #8
Well, they are all for portions of the air conditioning system. And, that's correct above that the rear window defogger will work, but will lose its indicator.
Old 12-15-2011, 10:56 AM   #9
Captain Slow
My Face Is Ridiculous
Captain Slow's Avatar
Drives: 2010 Toyota Yaris 3dr LB
why don't you just not use the A/C in the winter?
i mean if it's really gas savings you're after wouldn't removing the belt from the compressor be the best way to go? less drag on the motor.
Captain Slow is offline   Reply With Quote
Old 12-16-2011, 03:34 AM   #10
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
Of course you realize, captain slow, that the car has a single serpentine belt from crank, to alternator, to a/c compressor, don't you?
Old 12-16-2011, 06:16 AM   #11
bronsin
bronsin's Avatar
No but CS is a man of action and that is all to the good.
I have become a 7.5 amp fuse puller and and much happier for it.
Laast night i didnt plug the block heater in and this morning i will see how far the car goes before the cool engine light goes out.
And now there will be no AC to spoil things...
Hmm I wonder could they market a Yaris option optimized for fuel eficiency?
Old 12-16-2011, 08:52 AM   #12
DMZ
DMZ's Avatar
Drives: 2007 Yaris LB
I found an easy mod on a Tacoma forum that allowed one to disable the "AC on when defrost is on" by pulling a wire from a wire harness plug beneath the dash. I did it and it worked great. If I wanted to run the AC with the defrost, I could do it manually.
I no longer have my '07 Tacoma, but I wonder if the internal wiring for it is similar to the Yaris?
DMZ is offline   Reply With Quote
Old 12-16-2011, 12:06 PM   #13
No. I have a 2011 Tacoma and am familiar with that mod. On the Yaris the linking is done within the knob, so you have to disassemble to knob to do it.
Blown Fuse - Stereo !?! click.mine In Car Entertainment + Electronics (audio / video / alarm) 16 10-05-2017 09:35 AM
30A Power Fuse Instrument Panel Location? Kioshi DIY / Maintenance / Service 16 03-31-2013 07:53 PM
radio fuse Nodrog In Car Entertainment + Electronics (audio / video / alarm) 2 11-10-2011 07:10 PM
fuse box for fuse for brake lights drew999 General Yaris / Vitz Discussion 2 01-19-2010 03:38 PM
2009 empty, usable fuse location? schleppy In Car Entertainment + Electronics (audio / video / alarm) 3 04-23-2009 01:07 PM
