Old 12-19-2011, 04:04 PM   #1
theboneman21
Drives: 2007 Yaris Sedan
Dash part became unseated
Hello gang
2007 Sedan
See the attached. The air vent/hazard light/odo black part became unseated and fell into the console a bit
Used needle nose to get it a bit closer to being seated.
Not sure how I can "remove" the console to properly seat it. Any suggestions ?
Thanks in advance
theboneman21 is offline   Reply With Quote
Old 12-19-2011, 04:47 PM   #2
Kaykogi
Kaykogi's Avatar
Drives: 2009 Barcelona Red Sedan
The trim around the stereo and climate control knobs just pulls off. Start at the bottom and work your way up. They might be kind of stiff to get off, but the clips are sturdy so don't worry about breaking them, just pull straight out. The last piece is the one around the gauge cluster. Pull it out and then look at the bottom. There are some finger-like tab things that need to hook into the stereo bezel. They are what is keeping it from being completely seated now. Just slide the piece back into place and make sure it fits flush. You can find posts with pictures all over if you need them. Just search.
Kaykogi is offline   Reply With Quote
Old 12-19-2011, 06:06 PM   #3
theboneman21
Ok thx will try in AM when it's bright again and advise how it went
thanks
Old 12-21-2011, 04:28 AM   #4
theboneman21
Good to go
thx dood
Old 12-21-2011, 01:05 PM   #5
Kaykogi
Kaykogi's Avatar
Glad it worked for you
Toyota Silver Dash Kit Meteorite_Marty Cosmetic Modifications (Exterior/Interior) 72 04-13-2012 01:42 AM
2008 OEM S model Liftback Lip kit Part numbers PETERPOOP Cosmetic Modifications (Exterior/Interior) 17 07-26-2010 01:33 PM
NEED HELP - Yaris suspension part Trish General Yaris / Vitz Discussion 10 11-07-2009 01:44 PM
Trade upgraded radio and dash for base radio and dash??? Yarisguy13 Items for Sale by private party 4 09-17-2007 06:32 PM
dash problems...help needed foggy08 DIY / Maintenance / Service 1 01-25-2007 08:04 PM
