Old 01-04-2012, 06:40 PM   #1
quimico
Drives: Yaris HB 07
I need help with these parts!
Hey guys,
I need to replace the parts in red on my Yaris:
how can i find them?
quimico is offline   Reply With Quote
Old 01-04-2012, 06:56 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I normally start by looking at villagetoyotaparts.com since they still have diagrams. Once you find the parts in the pictures, get the part numbers and then order them from a parts dealer.
Old 01-04-2012, 07:01 PM   #3
tk-421
tk-421's Avatar
Drives: 5D-07-LB
http://www.toyotaparts.com/
Old 01-06-2012, 01:42 AM   #4
NateDogg
Drives: Toyota Yaris
Called a "Belt Moulding"
-Toyota Dealership
-Local Bodyshop
NateDogg is offline   Reply With Quote
Old 01-06-2012, 12:18 PM   #5
quimico
Drives: Yaris HB 07
Nice, i have found them at villagetoyotaparts.com like weatherstrip assy, front and rear door glass !
Thank you guys.
I have another question: the web shows that there are 2 stock codes for the weatherstrip assy, front door glass: 6821052110-6821052130 for the outer LH, and 6816052110-6816052130 for the outer RH. Both have the same description at the web.
http://www.villagetoyotaparts.com/pr...821052110.html
http://www.villagetoyotaparts.com/pr...821052130.html
How can choose the correct option if both are the same? I have seen the diagram and it is only one piece but with two stock codes for each side.
For the rear doors they show only two codes, for the RH and LH, but i have four ones for the front doors, i'm confused.
Sorry for my english, i don't write very well.
Old 01-06-2012, 12:55 PM   #6
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
I'm gonna make an assumption and say that LH and RH stand for left hand and right hand. so it would depend on whether you are using it on the driver side or passenger side. the tapers would be different. the description would be the same (I would assume).
I can't see your original post so I am not exactly sure what part you are looking for (my workplace blocks photo hosting sites ie, photobucket and the likes) so I can't be sure which one you want.
please check with other users here before making a difinitive choice though. it would make sense that it is what is meant but just because it makes sense doesn't mean it is what is meant.
Old 01-06-2012, 07:01 PM   #7
quimico
Drives: Yaris HB 07
I'm clear that LH and RH are left and right hand, the problem is with the parts for the front doors, they have 4 codes: 2 for the RH and 2 for the LH weatherstrip.
I have sent an email to villageToyotaparts sales team and they said me that it depends of the VIN of my Yaris, i have sent the # and the description of my car ('07 HB 5-Door 1.3L M/T) but i don't have answer yet.
Old 01-06-2012, 09:06 PM   #8
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
they jus wanna make sure you get the right part
5dr H/B
68160-52110 pass front door outer strip
68180-52100 pass rear door oute strip
OTA'sTOY is offline   Reply With Quote
Old 01-06-2012, 10:18 PM   #9
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
discountoyotaparts.com is good as well ive ordered 4 different replacement stock parts from them for much cheaper than I could find elsewhere.
Old 01-07-2012, 01:53 PM   #10
OTA'sTOY
OTA'sTOY's Avatar
Drives: '10 5dr
Thank you guys.
the reason for the rear is because 3dr H/B dont have rear strips
68210-52110 Driver Front 5dr H/B
68210-52130 Driver Front 3dr H/B
68160-52110 Passenger Front 5dr H/B
68160-52130 Passenger Front 3dr H/B
Old 01-07-2012, 04:12 PM   #11
quimico
Drives: Yaris HB 07
Yep, villagetoyotaparts emailed me today and sent the correct codes for the 5Dr version.
Codes finished in 52130 are for 3Dr version.
Thank you guys.
Well, i now am looking for the pillars covers some people said me that it is a common vynil moulding, but i don't want to put on my car non-original parts.
Old 01-07-2012, 05:49 PM   #12
OTA'sTOY
OTA'sTOY's Avatar
Drives: '10 5dr
they're called blackout tape
pass frt # 75921-52070 (No#1)
pas rear# 75923-52060 (No#2)
#75925-52061 (No#3)is for the tape on the pillar between the doors
Old 01-10-2012, 11:22 PM   #13
Profotoiam
Drives: yaris
They have awsome customer service if you have anyquestions just have them call you or them. they saved me 200 bucks on a rebuild because i was confused on s model to non s model and woulda had the wrong part
Profotoiam is offline   Reply With Quote
Old 01-18-2012, 09:50 PM   #14
quimico
Drives: Yaris HB 07
I finally bought the weatherstrips at www.discounttoyotaparts.com, the have better prices than villageToyotaparts.com, i am waiting for the shipping info right now.
Thank you guys
07 YARIS Liftback FOR PARTS benjomothians Items for Sale by private party 12 02-07-2012 01:53 AM
Aftermarket parts and Factory Warranty in Canada? jonathanq Canada 3 07-11-2009 12:17 PM
FS: C-One Parts new & used - Socal 03Z33 Items for Sale by private party 90 06-03-2009 10:08 AM
