Old 01-18-2012, 11:50 PM   #1
vdooone
Drives: 2009 Basic Yaris
2009 Hatchback Trailer hitch basket
Hi guys
I'm new to this forum. I am part of other forums for the vehicles I own...
I have installed the cruise control on my really bare Yaris. Idk if I should post the pictorial about how I did it since seems like everything has been done is already posted here.
But anyway, I wanna know what can I do to put in this car:
this scooter
using this hitch, and its corresponding basket:
They affirm in the Hitch site that the max tongue weight is 200lbs. The scooter weights 290lbs wet and i refuse to buy a trailer. I'd be hauling the scooter at 80mph up I-95 for when we go to NYC in the summer time.
Any attachments or extra welding I'd have to add in to reinforce this?. Any engineered suggestions from the really smart and car savvy guys here?
I really appreciate in advance your time and inputs.
vdooone is offline   Reply With Quote
Old 01-19-2012, 07:24 AM   #2
Have a 290 LB person stand on your rear bumper and you'll see the back end really sink (probably just about to the bump stops). The problem is that the weight will be behind the rear axle.
My snowplow on crashy is basically the same thing on the other end of the car. The first time that I mounted the plow to my home made plow frame (which ties to the bumper mounts and the lower front cross member), the plow immediately sank to just a couple of inches off of the ground. The whole plow assembly only weighs about 150 lbs, but having the weight that far in front of the axle created the issue. To compensate I had to make a custom 4" lift kit to raise the front suspension.
Old 01-19-2012, 07:24 AM   #3
Old 01-19-2012, 11:19 AM   #4
Mead
Drives: BSP Yaris LB 2007
you wanna hang 300lbs behind your yaris doing 80 mph you understand SIMPLE laws of physics? panic stop much? steer much?
this is job for a trailer but if you're serious, hang 150 lbs off the front and DRIVE SLOW
edit: I have the same Curt hitch, with 50 lbs of bicycle and rack i can feel the difference turning on the street, 80 mph is suicide
Mead is offline   Reply With Quote
Old 01-19-2012, 02:32 PM   #5
YAR1S
YAR1S's Avatar
yikes. get a hitch and a cheep trailer from Harbor Freight.
-Jen <3
Old 01-19-2012, 02:59 PM   #6
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
First question is, why do you need to go 80mph on the interstate in the first place? That's 15 over the speed limit... Hell, in Pennsylvania that's 25 over...
But, to the topic at hand, I'd bite the bullet and get a tiny trailer. When I moved to where I'm at now I loaded up my Yaris to the brim... like max capacity as per the owner's manual... and it wasn't the safest feeling trip in the world. I couldn't imagine taking that weight and moving a large amount of it to a floating basket attached to the back of the car...
Old 01-19-2012, 10:08 PM   #7
vdooone
I understand a bit a physics. But after all these inputs I learned one thing: Trailer
Now, with a trailer I guess I can haul big momma, maybe?
Anyone Have a trailer hitch on a Yaris?? Suey 1958 DIY / Maintenance / Service 58 08-05-2018 01:40 PM
'07 Yaris LB Hidden Hitch and Trailer Pics Z00KA General Yaris / Vitz Discussion 18 04-13-2012 10:40 AM
Just Bought a 2009 Yaris Hatchback 4 Cyl Auto!! CASH DEAL!! Good Deal?????? paguy General Yaris / Vitz Discussion 13 05-28-2009 10:51 AM
Trailer Hitch Wiring bldunne General Yaris / Vitz Discussion 1 01-30-2009 04:10 PM
