Old 02-06-2012, 10:49 PM   #1
Em_
Drives: 2007 Yaris
Exhaust rattle (not a heat shield)
So I get this exhaust rattle at low rpms 5-600rpm at idle with engine at normal operating temp
I went to a garage, lifted the car. Removed 2 loose heatshields and the rattle was still present
We managed to get rid of the sound by pulling downwards the 2 brackets that support the exhaust with rubber
It seems like the sound is was coming from the inside of the car which doesn't seem to be damaged (no scratches or visible damage)
It still does it but very slightly barely noticeable
I refuse to think that the cat is dieing on me the car has only 60000miles
Any suggestions?
Em_ is offline   Reply With Quote
Old 02-07-2012, 05:15 AM   #2
bronsin
bronsin's Avatar
Its not the transmission cable rattling is it?
Old 02-07-2012, 06:03 AM   #3
Em_
Drives: 2007 Yaris
Haven't checked that out But the sound is more like metal
Like you would hit a glass with a spoon slightly :S
Only does it when engine is at low rpm
Old 02-07-2012, 04:52 PM   #4
FrankM
Drives: 2008 toyota yaris/2000 mr2
when you fiend out let me know my 08 hatch back dos it too!
FrankM is offline   Reply With Quote
Old 02-07-2012, 05:53 PM   #5
Em_
Drives: 2007 Yaris
found the problem
it was the doughnut gasket right after the header
it was so thin that it was vibrating at the connection where the 2 bolts with the springs are vibration was going trough all over the exhaust pipe
Old 02-08-2012, 11:39 PM   #6
Viperoni
Drives: 2005 Toyota Echo
The donut gasket is a common thing to go.
They're about $60 with spring kit at the dealer... vs $20 on eBay (search ExhaustDirect or exdperformance).
2006 Saturn Ion Redline
Old 02-10-2012, 05:36 PM   #7
Em_
Drives: 2007 Yaris
part store had it for 15% with bolts
yeah i already had it changed on previously owned 3 echos
Old 04-23-2013, 08:48 PM   #8
cybrjoe
Drives: Yaris 07
Where did you buy it, i live in LAVAL me to
Thanks to answer to me fast.
cybrjoe is offline   Reply With Quote
Heat shield buzzing from exhaust ¿?¿ annn DIY / Maintenance / Service 1 04-08-2011 05:44 PM
Enkei's and Dunlops + Medalion Touring Exhaust 2manywheels Items for Sale by private party 40 04-04-2011 05:01 PM
Exhaust heat shield.... vital? Beer Jammer DIY / Maintenance / Service 1 09-17-2010 09:52 AM
2010 US 5 door stock exhaust, big rattle 127.0.0.1 DIY / Maintenance / Service 3 06-20-2010 09:39 AM
rear exhaust heat shield Toy Yaris DIY / Maintenance / Service 7 04-19-2010 06:03 AM
