Old 02-13-2012, 04:55 AM   #1
tyrone_yaris
Drives: Toyota Vitz 2007 facelift
Disable Airbag?
Hello,
Just wondering, is it possible to disable the airbag deployment in for the passenger / driver. In case we need to put in a baby seat or for any emergency?
Would appreciate how to if possible.
Tyrone
tyrone_yaris is offline   Reply With Quote
Old 02-13-2012, 06:08 AM   #2
bronsin
bronsin's Avatar
Look in your owners manual.
I believe there is a switch designed to do just that.
Old 02-13-2012, 07:04 AM   #3
The Yaris doesn't have a switch as some vehicles do. MicroImage sells a device that I developed that allows you to arm or disarm the passenger airbag. I developed it for people running aftermarket seats, but it would work for this purpose as well:
http://shop.microimageonline.com/Air...?categoryId=-1
Old 02-14-2012, 03:06 AM   #4
tyrone_yaris
Thanks
Bronsin the owners manual I have is in Japanese . Its a Jap import.
CTScott I dont think we have that switch here :) I remember the older models 2004 that I had, had a type of connecter called SRS in the engine bay but nothign of that sort here.
Old 02-14-2012, 03:56 AM   #5
BluYrs
ヴィッツ ドライバー
BluYrs's Avatar
Drives: 2006 3d 1.0 Linea Sol
Mine has the switch (you operate it with the key) for the passenger seat as standard (IMHO all EU market Yarii do). If you're in doubt, just open the passenger door and look at the side of the dash that goes against the door trim. I found a pic, it's right below the warning sticker.
The blue one
Old 02-14-2012, 04:17 AM   #6
tyrone_yaris
Thanks for helping BluYrs. I checked but I dont have that option on the dash. Maybe the Japs dont allow it in their country
Old 02-14-2012, 09:18 AM   #7
Originally Posted by tyrone_yaris View Post
Thanks
CTScott I dont think we have that switch here :) I remember the older models 2004 that I had, had a type of connecter called SRS in the engine bay but nothing of that sort here.
I just checked the Japanese EWDs. Your car does not have a switch and it does have the weight sensors under the passenger seat with the occupant classification ECU mounted under the front edge of the passenger seat (like the US ones do).
Unfortunately the occupant classification ECU has a different connector than the one on the US Yaris do, so the MicroImage module would not work with your car.
Old 02-15-2012, 03:09 AM   #8
tyrone_yaris
What's EWD? Pls forgive my ignorance So that means there's no way to disable the airbags in the Jap models??
Old 02-15-2012, 06:26 AM   #9
EWD = Electrical Wiring Diagrams.
Correct, at this point there is not really a way to disable it on your car.
Old 02-15-2012, 06:27 AM   #10
bronsin
bronsin's Avatar
So...you cant disable the passanger airbag when installing a child seat in the passangter seat?
With all the flap about kids getting killed by airbags it would seem Mother Toyota would have something for that?
Old 02-15-2012, 07:02 AM   #11
tyrone_yaris
Thanks CTScott
Old 02-15-2012, 07:24 AM   #12
Indeed - She has a disclaimer in the owners manual, which says that car seats are to be installed in the rear seat. Also, the occupant classification system prevents the airbag from deploying if the passenger weighs too little.
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
Airbag light won't turn off dubgil DIY / Maintenance / Service 128 08-03-2016 01:12 PM
Passenger Airbag Question RedStickHam DIY / Maintenance / Service 13 06-23-2013 04:39 PM
passenger airbag light problem (NOT stuck on) ersheff General Yaris / Vitz Discussion 3 10-12-2010 08:20 AM
WTB: Driver Airbag, Airbag Control Module, Upper Tie Bar opdmize Willing to Buy by private party 1 03-19-2010 01:01 AM
